Old 04-19-2008, 01:11 AM   #1
daman18
daman18's Avatar
Replacing gear position indicator
I'm about to replace my gear position indicator and i was wondering where the little clip piece on the end of the cord goes? anyone know?
daman18 is offline   Reply With Quote
Old 04-19-2008, 01:26 AM   #2
lurch115
lurch115's Avatar
Re: Replacing gear position indicator
on the steering column right below the indicator.... there should be a plastic shrouf that ends right near there....slide the clip over the edge of that and then move it up or down so that it is in the right spot for the gear you are in
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 04-19-2008, 01:33 AM   #3
lawson86
lawson86's Avatar
clips on the part near the selector needle that rotates when you use the shifter...
1984 sierra classic (daily driver)
1986 sierra classic (garage dust collector)
1986 silverado (garage dust collector)
lawson86 is offline   Reply With Quote
Old 04-20-2008, 05:32 PM   #4
us111
clip on mine was broke,held in place with screw
us111 is offline   Reply With Quote
