Old 04-19-2008, 02:37 AM   #1
shortbed70
shortbed70's Avatar
Do they make 6 lug rotors for
Does anyone make 6 lug rotors for a 72 spindle? I have 6 lug stuff now and dont want to lose my wheels and I have 72 spindels uppers and all the stuff but I don't want to go 5 lug. Any ideas????
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-19-2008, 03:55 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Do they make 6 lug rotors for
Yes they do. Check out Early Classic Enterprises. Look at this Google search. http://www.google.com/search?hl=en&q...=Google+Search
Keith
Convert to disc brakes.
Old 04-19-2008, 07:23 PM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
I did some research on this, you might want to try this:
Use the 72 spindle, use the wheel bearings and seal for a 1990 Chevy C2500 with the 7200 GVW (light duty 3/4 ton with 6 lug wheels), the rotor for the 1990 C2500, the caliper and pads for the 72 spindle.
From my findings, the wheel bearings are the same for the 1/2 ton spindle and the 3/4 ton light duty spindle.
At rockauto.com, the rotor is $45.79 each, inner bearing is $5.56, the outer bearing is $6.06 and the oil seal is $1.69. Both sides total $118.20 + shipping.
I have not tried this, but from the specs/dimensions that I found it should work.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-20-2008, 03:06 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Someone here tried this already. The depth of the rotor hat is different, i.e. the rotor/caliper will not align. I wish it were that easy...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-20-2008, 05:12 AM   #5
shortbed70
shortbed70's Avatar
Cool I'm glad that was said thanks for the info. ECE e-mailed me and said they have them for $89 ea.
Troy
Big Red Dog build
Old 05-20-2008, 04:23 AM   #6
68SSC10
68SSC10's Avatar
I Was Looking At Using The Spindle, 6 lug Rotors And Calapers From A Light Duty 2500....Looks Like The Upper Ball Joints Will Work , But I'm Not Too Sure About The Lowers...Anyone Ever used This Set Up??
I've Reached The Age Where Happy Hour Is A Nap!!
68SSC10 is offline   Reply With Quote
Old 05-20-2008, 04:29 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
From what I read on this site, you need to change out the lower a arms to 67-70 3/4 ton arms and then use the late model lower ball joints.
chevy_mike is offline   Reply With Quote
Old 05-20-2008, 04:46 AM   #8
68SSC10
68SSC10's Avatar
I Remember Reading Something Along Those Lines On Here Someplace, But I Couldn't Find It.....
Old 05-25-2008, 05:31 AM   #9
70C10Toejam
Hellasick
70C10Toejam's Avatar
Here's that thread:
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 05-26-2008, 11:59 PM   #10
68SSC10
68SSC10's Avatar
Thanks For The Link!!
Old 05-27-2008, 06:51 AM   #11
70rs/ss
70rs/ss's Avatar
I was about to try this very thing since I already have a set of 2" spindles from an 88 and up truck. You use the stock 72 upper arm and ball joint, with a 3/4 ton lower arm and the later model ball joint to match the spindle. then of course you use the rotor, caliper etc from the late model set up. Stock stuff could be had from a wrecking yard on the cheap and rebuilt parts from Checker or whatever, but since the OP has the 72 disc spindles, it is cheaper and easier to just buy the 6-lug rotors. Just know that these are a special part that can only be had from ECE or the like, so maybe buy a spare for just in case, cause you can't buy one from Checker, etc. With the later model swap I was mentioning above (and others) these are redily available parts from any local parts house, as well as having support from the aftermarket with slotted, cross drilled rotors, bigger rotors and caliper for a more reasonable price then modding 72 vintage stuff.
70rs/ss is offline   Reply With Quote
