04-19-2008, 05:01 AM | #1 |
Hey guys I need some help!
Yep I need a hand figuring out what H2o temp sender to use in LowBuck.
You see I want to use the stock dash gauge but the stock sending unit is like a 1/2 NPT and my 92 LT1 only has a 3/8NPT spot in the head. I have already re-wired the fire wall bulk head and hooked the wire up to a sender I had found but it reads way off. The parts store can't tell me what Ohms the gauge or sender is stock so I have no way of finding a cross over sender for my application. Does any one have a part number for the correct sender but in a 3/8NPT size? Tell you what the first person who can give me the right part number that works corectly I will send out a set of ether cab dolly or cab lift plans for your help! Kevin LFD Inc. |
04-19-2008, 05:30 AM | #2 |
Re: Hey guys I need some help!
Sounds like a ? for 68 short step...maybe he'll chime in!
R.I.P. Killer 71 10/26/07 |
04-19-2008, 05:40 AM | #3 |
use your stock temp sensor (for the carbed engine) and use a 3/8npt to 1/2npt adaptor....that make sense???
04-19-2008, 05:44 AM | #4 |
04-19-2008, 05:52 AM | #5 |
get me some pics please.....
or refer me to one of the million pages of "low buck" Last edited by 68 short step; 04-19-2008 at 05:53 AM. |
04-19-2008, 06:11 AM | #6 |
04-19-2008, 06:16 AM | #7 |
I am a Referee of life.
Use a 3/8 ths to 1/2 inch street 90* ell.it should give you enough room.Just a suggestion but it looks like it would fit.At least it might get you going until you find something that would look better.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-19-2008, 06:19 AM | #8 |
If you have the room, and feel brave, you could tap out the hole in your head to the bigger size. I've done it on intakes before, and if you're careful it works/seals fine.
Someone offered a few of the stock 67-72 senders turned down on a lathe and re-threaded about a year ago on the parts board. I don't remember who that was though.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
04-19-2008, 06:29 AM | #9 | |
I would rather not us an adapter due to looks but if it my only choice I would do it. I will also concider the lath trick if I can find someone with the right die for 3/8npt. As for tapping my head, nope not that brave Kevin LFD Inc. |
04-19-2008, 06:42 AM | #10 |
Have you tried using a 1/2 to 3/8 bushing instead of the adaptor. They also make a face bushing that looks like a helicoil that should give you the clearance
04-19-2008, 06:51 AM | #11 | |
Kevin LFD Inc. |
04-19-2008, 06:56 AM | #12 | |
04-20-2008, 01:11 AM | #13 |
72 Chevelle Club
Someone please help I have the same trouble with my Dart heads !!
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
04-20-2008, 02:04 AM | #14 |
I did some digging today at work and came up with something maybe kind of close. These are Carquest part numbers.
The TS6 is the factory 1/2" sending unit. These are its specs-- Closes at 100F at 368 ohms at 32 tolerance Opens at 220F at 80 ohms at 125 tolerance The closest ohm match I could find in a 3/8" sending unit was a TS225. Closes at 100F at 239 ohms at 10 tolerance Opens at 220F at 28 ohms at 6 tolerance I have no idea what the tolerance means, but this is the closest sending unit I could find as far as ohms are concerned. I looked at a picture, and this is a compact sending unit that would work well there...if it would read halfway decent. It was used only on Fords, but I forgot to write down what applications. The part number should interchange... Maybe it will work? Last edited by drman929; 04-20-2008 at 02:06 AM. |
04-20-2008, 02:05 AM | #15 |
Wasnt it Green Machine that had some specially made & was selling a few here a while back? May want to send him a PM & ask...
04-20-2008, 03:01 AM | #16 |
member #16
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-20-2008, 04:05 AM | #17 | |
04-20-2008, 04:41 AM | #18 |
not sure of the specs but i just built a late 50's y block[292 v8 ford] that took a very short 3/8 sending unit
common sense isn't so common anymore |
04-20-2008, 06:01 AM | #19 | ||
Thanks to all for the help as I have been driving LowBuck on a daily basis and have done over 5k miles in the last few months and it runs great but it is always in the back of my mind "What If". I will let you all know what come out of this. Kevin LFD Inc. |
04-20-2008, 07:00 AM | #20 |
There is a lot of brass meat on the temp sender. I believe you can turn the 1/2" id to 3/8" and pipe thread it 3/8NPT.
There is a post somewhere in the monster pile of archives of this being done by another member.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-20-2008, 07:04 AM | #21 | |
Kevin LFD Inc. |
04-20-2008, 03:11 PM | #22 |
Too Dumb To Know Better
Kevin, I'm sure we got the temp sender for my 94 lt1 from NAPA. I'll look around and see if I can find the invoice. It has been 2 years since then, so don't hold yur breath.
04-20-2008, 05:56 PM | #23 | |
Kevin LFD Inc. |
04-21-2008, 05:09 AM | #24 |
Well we did some more checking today and found that the ones listed above would still be way off for my gauge reading. I had called a freind of mine yesterday to ask him about it and I guess it bugged him that he did not have an answer so he made this. He took a hydro fitting and an NPT coupler and silver soldered them together. He may have to do another one that is a bit longer because this one lets the sender bottom out just before it gets tight. I will try a few things on Sunday to see how it goes.
Kevin LFD Inc. |
04-21-2008, 05:52 AM | #25 |
Ah shoot, I thought you didnt have room for an adaptor...
