Old 04-19-2008, 05:02 AM   #1
72YellowBird
Installing Eagle Rims
I am thinking of purchasing a set of Eagle rims on my 98 GMC 4x4 and I did a test fit before mounting the tires and found that the center bore of the rim was larger then the axle hub. So the weight of the truck is on the stud bolts instead of the axle hubs. I know there is a spacer kit available to make the hole in the rim match the truck.
I am wondering if anyone else has had this issue or does anyone know if there is year specfic rims available through Eagle for GM trucks??
72YellowBird is offline   Reply With Quote
Old 04-19-2008, 05:21 AM   #2
ed2552
ed2552's Avatar
Re: Installing Eagle Rims
My tahoe rims are like that, you are thinking brakes IIRC, The rims don't matter as far as i kno
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-19-2008, 05:41 AM   #3
72YellowBird
Sorry dont have any pics right now. Do you happen to know the center bore on your rims? My truck has the 6.5L diesel and 4X4 so i have a fair amount of weight on the front end. I want to make sure the rims will stand up and i will have no other issues with vibrations.
Old 04-19-2008, 06:16 AM   #4
ed2552
ed2552's Avatar
Idk, it is like 3-3.5 in, 18x9 Helo MAXX 6 wheels, from what i can tell,
