04-19-2008, 05:13 AM | #1 |
voltage regulator mounting location
can someone post a picture of the stock voltage regulator mounting and fasteners. I have found the 3 holes where it mounts and it appears that the plug goes towards the headlight on the drivers side on the 68????
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
04-19-2008, 06:54 AM | #2 |
'71 chevy s.bed/s.side
Re: voltage regulator mounting location
I don't have a pic yet, but those rubber grommet/nuts are still available from GM, I just purchased them. I can get ap/n tomorrow.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
04-19-2008, 07:05 AM | #3 |
Here's a pic
04-19-2008, 07:07 AM | #4 |
Hear are some pics from toddtheodds's post on converting from external to internal regulator. hope it will help.
69 C10 LWB GM 350 crate motor, 3.73 rearend |
04-20-2008, 03:39 AM | #5 |
I am in need of the rubber gadgets. are they mounted and act as insulators from ground? I doubt this because the coils inside wouldn't work . Or is it just for a shock/vibration neutralizer?
04-20-2008, 03:52 AM | #6 |
its all about the +6 inches
its for shock reasons.
04-20-2008, 04:52 AM | #7 |
so if i cut some 1/8 inch rubber sheeting and make a pad either side of core support and use some fender washers out front.... sounds like it could work
