fuel gauge sending unit testing
I have installed my tank and it is empty of course ( will have to take out another loan to fill it) HA! anyway i decided just for kicks to put a meter on the terminal and ground .............it has full continuity through the meter. I assume this is typical since the gauge and al;l worked fine before the tank was removed////?????????
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Trucks N Tranzams
Re: fuel gauge sending unit testing
If the tank is empty, the meter will show 0 ohms or no resistance. You can always remove the sender from the tank and test it as well. When it is full it will show 90 ohms.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
so what I see is full continuity or zero ohms?
sorry, I don't use OHM meters enough to understand. I use them as a continuity tester or a volt meter to trace wires with. If I follow you, the fact that the meter goes way up , meaning good continuity to me, when the meter is set on the ohms scale, then if it was full the meter would read low?
#5 | |||
Union Electrician
No ohms=continuity, when in the empty position, when sending unit is moved to full position the meter should be reading 90 ohms.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Thanks, I will check it out.
