Old 04-19-2008, 05:22 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Removing transmission
I have my engine out, and want to paint my fire wall. I noticed I wont be able to get at the area as well as I would like, and need to pull my TH350.
Is there anything I need to do, or watch out for?
Will I have to jack up the truck and lower it from underneath?
I'm thinking I'll bolt it up the motor and stab it in all at once. Is this a good idea?
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-19-2008, 08:35 AM   #2
finch
finch's Avatar
Re: Removing transmission
that is the only way to do it IMO. that way you don't have to mess with trying to get the top tranny bolts in. easiest way to do it would be to get the truck on jackstands, unbolt the crossmember and trans, jack up the trans and make sure it is secure, slide the crossmember out of the way, and lower the trans. this is the way i have done it in the past, maybe someone has a different method..
good luck!
andy
finch is offline   Reply With Quote
Old 04-19-2008, 04:09 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
With the front body clip out of the way you shouldnt have any trouble getting it all in or out as one piece.
sneakysnake is offline   Reply With Quote
Old 04-19-2008, 07:35 PM   #4
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
If you can, brace the frame rails side to side. When i unbloted my crossmember, slid it back and took the trany out, on reasembly, the fram and bowwed in. I couldn't get the top 4 bolts back in the frame to the crossmember.
Wedge a 2x4 in there before you unbolt it. or something. That thing was a monster to get back in.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 04-19-2008, 09:41 PM   #5
graverobberATL
graverobberATL's Avatar
S/T, you don't have to unbolt the crossmember from the frame. All you have to do is unhook everything from the tranny and pull it out through the front and when you put it back in (all in one piece) you just have to pick up on the tail of the tranny to get it over the crossmember and just line everything back up and bolt it up.
graverobberATL is offline   Reply With Quote
Old 04-21-2008, 12:33 AM   #6
Wrenchbender Ret
I would raise the front of the truck, put a jack under the trans. take the board out & cover the trans with plastic & paint.
Wrenchbender Ret is offline   Reply With Quote
Old 04-21-2008, 12:48 AM   #7
Sport/Truck
Sierra Grande Club
Thanks for the suggestions! wrenchbender- I need to be able to roll it outside before I paint it.
s/t
