Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-19-2008, 10:11 AM   #1
streetstar
streetstar's Avatar
Nitrous fuel pressure
I would like to run a mechanical fuel pump (high gph one) , would that be a no-no with a 175 shot from a cheater plate system?
And what kind of pressures do you guys regulate it at with a milder system like that?
Engine is a stock 454
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-20-2008, 04:50 AM   #2
57sailplane
57sailplane's Avatar
Re: Nitrous fuel pressure
i was thinking of using one of these.. looks like the best deal out there... http://cgi.ebay.com/ebaymotors/Bille...spagenameZWDVW
57sailplane is offline   Reply With Quote
Old 04-20-2008, 06:22 AM   #3
BADGMC
BADGMC's Avatar
Use of a good mechanical pump with 5-7psi should work fine on a stock 454 with that hp kit. This assumes fuel lines are proper size for the pump with a good pickup in the tank. I had a blown SBC that made 550 hp with a CV Products mech pump.
As for the Racepump. I ran one on my current twin turbo blow through 383 and it worked great, when it worked. At first it was the o-rings on the piston that would go bad. I had to change them on the side of the road 3 or 4 times. I had the pump updated with teflon rings and that fixed that problem but upon a hard launch at the track it wouldn't pull from a rear fuel cell even under 1.50 60ft launches. The pressure would drop right at the shift to second gear right to zero. I didn't want an electric pump but had to go to one as it was too much of a gamble. Let me tell you there's nothing worse than rebuilding a hot fuel pump on the side of the freeway under a street light.
85 GMC 1/2 ton LWB 4150lbs.
383 SBC with Twin MPT70 Turbos 850 CSU carb
TH375 3.70 gears Ultimate 10" Converter
10.11@136.6 with 1.64 60ft. on 10.5-31-15W
BADGMC is offline   Reply With Quote
Old 04-21-2008, 09:31 PM   #4
streetstar
streetstar's Avatar
Thanks guys -- thats what i needed to know
I estimate my stock 454 at 275hp (except with tons of torque), so even the big shot jets will put me at a max of 425 - 450 ---
i can't wait to try it at the Friday TT night drags --- i am trying to be realistic so i am only hoping for low 15's in the 1/4.
If i have enough fun with the thing, i might try to wake it up a little more , but who knows
Old 04-22-2008, 04:34 AM   #5
djracer
djracer's Avatar
if I were you I would start with a smaller shot (say 100)and work my way up!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
