"brand new second-hand"
rearend swap .....anybody know
Anybody know what late model rearend can be swapped into a 69 coil spring truck-c-20? what available etc....
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
its all about the +6 inches
Re: rearend swap .....anybody know
if you can cut and weld, then most of them will work, if you can't cut and weld, then none of them will work.
Thanks for the info-I read somewhere that you can buy the spring mounting plates and the bracket for the panahrd bar-do you know a source?...thanks much again
WTB this ad
I want to say that Early Classic sells the mounting pads. The track bar.....You may have to go to a Super track bar that mounts to the trailing arm.
I think see ten is right.
I had forgotten all about that kit. I would imagine there is still welding involved, but that may be no big deal for you. |
