1988-1994 steering wheel - direct bolt on or
Does that year steering wheel bolt on directly or do you have to modify anything(shifter, turn signals or levers) I've seen a few pics, but have not been able to find anything on installing
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
Active Member
Re: 1988-1994 steering wheel - direct bolt on or
Bolts right in....nothing needs to be modified. The only thing I'm not sure about is the horn, my didn't work before and still doesn't
1971 SWB SOLD
Gettin By on Gettin By
Heres mine from and s10, 92 i think. Bolts right on with no problems. But the horn doesn't work. That is tomorows project, i'll post some pics if i can rig it up.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
I have a wheel from that era and it bolts right up. Looks good too.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
![]() Join Date: Mar 2005
wheel bolts right up. you have to use the wiring and horn button from that year model wheel.
its all about the +6 inches
I did a write up on this a few years ago, it's in the FAQ part.
http://67-72chevytrucks.com/vboard/s...steering+wheel |
Bolts right in and pull the horn tab out and stick the wire out of the new truck in.
My Rides 1969 Mustang gt coupe 1971 Chevy Cheyenne 1986 Iroc camaro 1986 K10 Short Bed 1987 Iroc Camaro 1990 rs Camaro 1992 350 ss truck 1998 Honda Civic 2005 Ram 2500 Cummins My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=279831 |
