Old 04-19-2008, 10:07 PM   #1
coggonobrien
what is the 4sp manual in a 68 3/4 ton
just wondering what the name is and if there's any aftermarket support for it performance wise. i'm buying a 68 3/4 ton chevy longbox 2wd.
thanks,
Dave
coggonobrien is offline   Reply With Quote
Old 04-19-2008, 10:10 PM   #2
kyull67
kyull67's Avatar
Re: what is the 4sp manual in a 68 3/4 ton
I believe it should be the SM465. Does it have the granny gear. They are supposed to be pretty strong. If I'm incorrect someone will let us know.
kyull67 is offline   Reply With Quote
Old 04-19-2008, 10:28 PM   #3
cruiserman
Yep, sm465
sm420 up to 1967.
Cast iron and fairly bulletproof. Just keep it full of fluid.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 04-19-2008, 10:31 PM   #4
kwmech
Got an NP435 in my 68 GMC
Old 04-20-2008, 12:06 AM   #5
lilred67
lilred67's Avatar
what motor do you have in front of it? i have a '68 gmc 3/4ton with a 305 v-6/ 4-speed and was wondering what tranny it had....thanks
lilred67 is offline   Reply With Quote
Old 04-20-2008, 12:31 AM   #6
coggonobrien
cool thanks, is there a hurst shifter that will work with it?
Old 04-20-2008, 01:26 AM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
It's either the 465 or the NP 435 Close Ratio as mentioned above.
Don't know about that,but don't be expecting any fancy shifts with one of these,they aren't designed for it.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 04-20-2008, 01:27 AM   #8
factorystock
factorystock's Avatar
The SM 465 was the standard 4 speed in 68. I believe the NP 435 was the close ratio option, but still a heavy duty 4 speed with low 1 st gear.The NP has an aluminum top cover. Both have the reverse on the right side and down.The SM 420 was last used in 67 (reverse is on the left side and down).These transmissions are not designed for performance, were designed to do work and stay out of the repair shops.
factorystock is offline   Reply With Quote
Old 04-20-2008, 02:12 AM   #9
67_C-30
I have a radical idea!
67_C-30's Avatar
I agree totally with factorystock and WorkingLonghorn.
lilred67, the NP435 is pretty common behind the V6's. I have one truck with a 351E V6 and another with the 305E V6 and they both have the NP435. The easiest way to tell is look under the truck and see how many PTO plates it has. In a '68 if it has 2 it will be a SM465 and if it has 1 it will be the NP435. This only applies to the '68 - up models because the '67 will not have a SM465 option. It will either be the SM420 or NP435, and you can tell which is which by where the reverse gear is on the shift pattern as factorystock said.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-20-2008, 02:27 AM   #10
msgross
msgross's Avatar
Here is my 465 from the 68 K-10. of course it has a transfer case behind it though....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-20-2008, 11:00 PM   #11
GMCBubba
GMCBubba's Avatar
no guarantee that the NP 435 is close ratio. i seem to have the np435gl with the super low granny gear. i think. originally came behind a 307. definitely not a drag racing setup. but good for it's original purpose of hauling a bed and trailer full of grain or hay.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
