Old 04-20-2008, 02:37 AM   #1
SBCustoms
Complete Street Customization
SBCustoms's Avatar
New carrier bearing for two-piece driveshaft
Does anyone know where i could find a new carrier bearing for my two-piece driveshaft? any help would be greatly appreciated.
1968 GMC SWB (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=269230)
1998 Chevrolet Silverado Z71
Southern Born Customs
Knoxville, TN
865-934-9126
SBCustoms is offline   Reply With Quote
Old 04-20-2008, 02:47 AM   #2
EyeH8the24
EyeH8the24's Avatar
Re: New carrier bearing for two-piece driveshaft
napa carries them here ...but they r crappy....and break quick .maybe someone else will chime in with a bullet proof solution..
EyeH8the24 is offline   Reply With Quote
Old 04-20-2008, 02:48 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Any parts store should be able to get you one. Once you have it in your hands, take it to someone who can weld (or do it yourself) and have the metal cover/cage (for lack of a better description) welded a bit better.
Or, if your driveshaft actually needs a new C-bearing, just toss it on the counter at your local drive shaft shop and have them press a new one on. (A hammer has no buisness around a shaft that spins at those RPMs) have some new U-joints and a spin ballance on the shaft and it'll be good for a long time.
Old 04-20-2008, 03:44 AM   #4
dadsbrew
dadsbrew's Avatar
1970 K-10 400CID, to much cam--not enough compression Stan's Headers and a 4" lift / 1990 R1500 Suburban 4X4, 350CID with vortec heads, edlebrock intake, TBI, 10:1 compression and Stan's Headers
"The probability of someone watching you is directly proportional to the stupidity of your actions"
dadsbrew is offline   Reply With Quote
Old 04-20-2008, 03:45 AM   #5
rick0312
rick0312's Avatar
I used the one on the left in the picture, which is the stock bearing on my truck. The one on the right is nice but cost a bit more. I am gonna take Longhorn Man's advice and beef up the support with additional welding.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 04-20-2008, 03:51 AM   #6
dadsbrew
dadsbrew's Avatar
Where did you find the one on the right ? That one looks tuff.
Old 04-20-2008, 04:26 AM   #7
jlaird
jlaird's Avatar
Inland driveline
http://www.iedls.com/bearings.html
jlaird is offline   Reply With Quote
Old 04-20-2008, 04:28 AM   #8
EyeH8the24
EyeH8the24's Avatar
i have used the one on the left cuase its all i could find and they never last long..the rubber always seperates ...i dont see how any kind of welding could prevent this.i have one on my 69 that has only been driven ..at the most 5 miles,in my yard at that,,never been abused and the rubber has broke away from the mount
Old 04-20-2008, 04:36 AM   #9
CG
BlahBlahBlah
I think PICKMUP carries the one on the right. Seems like I saw one on one of his shelfs last time I was down there.
Old 04-20-2008, 07:36 AM   #10
dadsbrew
dadsbrew's Avatar
I've used the one on the left also, the trick is making sure you align your u-joints correctly and having it balanced will make all the difference in the world and it will last years.
Old 04-20-2008, 08:38 PM   #11
lytemup454
lytemup454's Avatar
does it need to be pressed on to the drive shaft?
lytemup454 is offline   Reply With Quote
Old 04-20-2008, 09:45 PM   #12
Michael12
LMC has them... depending on what Bearing you have, 1.3780"ID 2WD 67-72 19.95 part # 34-1670 or 1.5748"ID 67-72 19.95 part # 34-1673... or most commonly on our trucks 1.1811"ID 67-72 16.95 part # 34-1671
Michael12 is offline   Reply With Quote
Old 04-20-2008, 10:03 PM   #13
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Wes at Classic Heartbeat one of the site vendors sells bearings just bought mine from him, the type that fits on mine is the horseshoe type pictured here.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-20-2008, 10:43 PM   #14
Longhorn Man
all carrier bearings need pressed on.
That shaft spins 2500 - 3500 RPM @ 70 MPH when you are on the freeway, depending on your gear ratio. A hammer doesn't belong anywhere near anything that spins like that.
Old 04-21-2008, 06:02 PM   #15
SBCustoms
SBCustoms's Avatar
thanks for all the help guys, i guess ill just take it to the driveshaft shop and let them do it, because it needs to be shortened anyway! since it needs to be balanced for the bearing to last long, they could just do it.
Knoxville, TN
865-934-9126
Old 04-22-2008, 05:36 AM   #16
rick0312
rick0312's Avatar
I hamered mine on ever so gently with a socket. It went on fine, but I have yet to run the shaft.
Old 04-22-2008, 06:25 AM   #17
truckdude239
truckdude239's Avatar
i installed mine when i did the trans new u joints lasted 3 months maybe 200 miles installed a new one from advance lasted 2 months, advance gave mea replacement i installed it but didn't putt he sheilds back on and it has yet to break again but this was 2 months before the motor went out
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-22-2008, 06:37 AM   #18
Longhorn Man
you probably have another problem then.
Old 04-22-2008, 06:46 AM   #19
jhow66
jhow66's Avatar
Got mine from Napa a few years ago. (Behind a 502HO) still smooth as silk).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-22-2008, 06:50 AM   #20
Pont406
Carrier bearing is not too hard to change if you have a press. For what shop will charge you, might as well buy a press. I got mine cheap at harbour freight and I love it.
Pont406 is offline   Reply With Quote
