04-20-2008, 03:42 AM | #1 |
Rear widths..
Can anyone tell me the width of the 5 lug rears (I think late 70-73)? Thanks in advance.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
04-21-2008, 08:33 AM | #2 |
Re: Rear widths..
I think they are wider than your stocker!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
04-21-2008, 11:11 AM | #3 |
Registered.........
Re: Rear widths..
Stock width for a 1966 is 62" from drum to drum (point where the wheels mount).
The width for a 1971/1972 is 63.5" from drum to drum. The 1973 up rear ends are wider still.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life Last edited by wild one; 04-21-2008 at 11:12 AM. |
04-21-2008, 04:16 PM | #4 | |
Re: Rear widths..
The later model disc brake explorer 31 spine 8.8's are 60.25 wide. Thats a pretty decent rear for the money.
04-21-2008, 08:22 PM | #5 |
Re: Rear widths..
So rear track width would narrow up 1" on each side with a 61.5" rear.. I have a later 71+ 5-lug rear.
05-04-2008, 06:25 AM | #6 | |
Re: Rear widths..
What rearend are you using now?
Anthony |
05-04-2008, 08:03 PM | #7 |
Re: Rear widths..
By my calculations (should have measured when the wheels were off) it's 63.5" wide. My tires messure out to almost exactly 12" I have a 12" draglite with a 7.5" BS. So total width tire edge to tire edge is 74.5" - 11" for the total BS and I get 63.5".
I am looking for a 9" right now that is 61.5" - 63.5" to replace the 12 bolt with. Any suggestions would be great.
05-04-2008, 10:00 PM | #8 |
Re: Rear widths..
the exporer rear would be just a little narrow at 60.25 with 31 spline axles. just put a spool in it and it sould be pretty good for cheap.
05-05-2008, 04:20 AM | #9 |
Re: Rear widths..
Any idea on the gear ratio? I'm just not to sure about going that narrow. Did you gt the one in your uncls truck. What wheels are on it. Can you snap some pics?
05-05-2008, 06:24 AM | #10 |
Re: Rear widths..
I haven't done his yet! I will do my little brothers first! I run a 4.30 with a 33 tire. I might do a 3.73 or 4.10with your shorter tire and spray it dead out of the hole!
