Old 04-20-2008, 08:05 AM   #1
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Engine cleaning!
Can someone tell me the best way to go about cleaning a GM350 small block. After I get it out of my truck I want to take it apart and give it a good cleaning. Is there a good engine degreaser that I should use that wont harm any parts?
jgrisafi is offline   Reply With Quote
Old 04-20-2008, 08:28 AM   #2
jhow66
jhow66's Avatar
Re: Engine cleaning!
Pressure washer for outside.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-20-2008, 08:56 AM   #3
HoupPhotography
Disagree on the pressure washer unless your taking the motor apart OR your very careful around the gaskets.
The best way is engine degreaser and\or carb cleaner and a wire brush..... but it depends on how dirty it is..... BE VERY CAREFUL WITH ANY LIQUIDS WHEN CLEANING YOUR MOTOR!
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 04-20-2008, 04:49 PM   #4
jhow66
jhow66's Avatar
The best way is engine degreaser andor carb cleaner and a wire brush..... but it depends on how dirty it is..... BE VERY CAREFUL WITH ANY LIQUIDS WHEN CLEANING YOUR MOTOR!
I was assuming it was coming apart.
Old 04-20-2008, 05:02 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I rented a Hotsey hot water cleaner and cleaned every thing before I rebuilt the motor. The hot water cuts through the grease and a little cleaner helps too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-23-2008, 06:54 AM   #6
ShowSS12
ShowSS12's Avatar
if yu dont' mind me asking how much to rent one of those things?
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 04-23-2008, 07:47 AM   #7
Farmstore34
Farmstore34's Avatar
If you are planning to tear it down and replace bearings and misc I would suggest taking the big parts to a machine shop and have them hot tanked. That will get the heads and block thoroughly cleaned inside and out. Be aware that any aluminum parts (cam bearings, etc) will be melted away.
Farmstore34 is offline   Reply With Quote
Old 04-23-2008, 03:55 PM   #8
jorgensensc
jorgensensc's Avatar
Castrol super clean (purple jug at wally world in auto section) and a pressure washer.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-23-2008, 04:09 PM   #9
Shyguy
Junior Member
Shyguy's Avatar
Great pictures s/t.
Most of the time all we see is the result of people working on their trucks.
It is good to actually see some work being done.
Danny
Shyguy is offline   Reply With Quote
Old 04-23-2008, 04:32 PM   #10
Chris4x4Gill2
I let the machine shop clean the major parts such as the block and heads.
The Everything else I used a concentrated Degreaser from Harbor Freight. I mixed it pretty heavy and then let the parts I wanted to clean soak in a shallow pan of the stuff for a few days. This worked great for the tins and such, but be careful of anything that will rust.
Chris4x4Gill2 is offline   Reply With Quote
Old 04-23-2008, 04:37 PM   #11
Premium72
Premium72's Avatar
i hear oven cleaner is a good engine cleaner. i never tried it. but they say it works.
Premium72 is offline   Reply With Quote
Old 04-23-2008, 05:02 PM   #12
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
Simple Green full strength and a lot of different size stiff brushes will do the trick
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242380
Sequoyah is offline   Reply With Quote
Old 04-23-2008, 06:30 PM   #13
cdowns
cdowns's Avatar
with the many hundreds of engines that i've had and cleaned i've never had a problem with gasket damage due to pressure washing
Old 04-24-2008, 04:20 AM   #14
arkracing
Weekend Warrior
Shawn
x2
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 04-24-2008, 04:44 AM   #15
1956cameo
1956cameo's Avatar
I have had great success with some stuff called "Purple Power" use it at full concentrate. You can get it at Wal-Mart, Autozone, or anywhere auto parts are sold. Spray it on, scrub with brush, hose off. Repeat until clean. Gets all of my motors and frames spotless from oil and grease. Doesnt take very long and is really cheap $6-$8 a gallon. If you can use in combination with a pressure washer it will speed up the process to one or two scrubbings.
1956cameo is offline   Reply With Quote
Old 04-24-2008, 04:58 AM   #16
El Jay
Gone to greener pastures
"Greased Lightning". Available just about anywhere cleaning stuff is sold; grocery store, Ace, etc.
Then hook your garden hose to the drain on your water heater.
Spray on the Greased Lightning, let it set for a few minutes.
PUT ON SOME SAFETY GOGGLES, OR SAFETY GLASSES @ the minimum, and then hose it off.
Obviously you have to cover sensitive things like the carb & dizzie.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-24-2008, 05:08 AM   #17
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
I used the dollar general brand oven cleaner on mine. Worked very well.
Jason
jay_shy is offline   Reply With Quote
Old 04-24-2008, 05:47 PM   #18
jorgensensc
dollar store oven cleaner works, but it will take the paint off. that is what i use when I pull an engine and want to clean up the engine compartment.
Shawn
Old 04-24-2008, 07:54 PM   #19
Russell
Professional Grade
Russell's Avatar
I always use easy off. Spray it on, let it sit for 15 - 20 minutes then hose it off with a pressure washer.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-24-2008, 08:35 PM   #20
BowTieOgre
I used oven cleaner on my last 2 motors. I gave it a heavy coating and took a spray bottle with hot water/simple green and a toothbrush and started spraying the engine at close range while giving it a scrub. I went back and gave it a good wipedown and laid some paint on it.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 04-25-2008, 08:22 AM   #21
rickf
rickf's Avatar
Most oven cleaners use caustic soda, aka lye, aka sodium hydroxide. Same stuff as most drain cleaners. So you'd be washing the engine essentially with diluted Drano.
That's not really problem for iron, but it is a big problem for skin and aluminum. Sodium hydroxide reacts with aluminum and one of the by-products is hydrogen. Odds are you won't produce enough hydrogen to blow up the garage, but the stuff is going to etch your once shiny aluminum.
Best to stick with degreasers that are just about degreasing, eg. Gunk or the purple jug stuff, and stay away from the chemicals meant to reduce almost everything to sludge.
rickf is offline   Reply With Quote
