Old 04-20-2008, 06:21 PM   #1
71jimmy
71jimmy's Avatar
Center Hump
I just removed my center high hump to do some painting. I'm wondering, was there a factory seal bt. the hump and floor? Was the seal rubber or silicone or? (I don't think silicone had been invented back in the day) Looks like remnants of some type of sealer, but there is too little and it's to old to tell if it was factory or something a PO did.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-21-2008, 12:09 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Center Hump
My 69 K20 had a rope type gasket in there when i yanked it. I don't think I used anything when I put a different hump in there. If anything, I'd just run a bead of blue silicone and call it good.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-21-2008, 02:28 PM   #3
vtblazer
vtblazer's Avatar
Re: Center Hump
Believe the rope style gasket is what the factory used on all of em, it's your choice from here...
Fresh paint and no pics? Boo...
vtblazer is offline   Reply With Quote
Old 04-21-2008, 03:51 PM   #4
jaros44sr
jaros44sr's Avatar
Re: Center Hump
There is a 1/2 circle indentation all the way around it, I was thinking a foam door seal from Home Depot but I think that mite retain water, so I'll have to come up with another matrl., JAT
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-22-2008, 06:34 AM   #5
71jimmy
71jimmy's Avatar
Re: Center Hump
Thanks for the replies guys.
I should have said new primer instead of new paint. It won't have actual paint for several years the way this is going.
I'll probably just use silicone to seal it. I've never heard of rope style gasket. Is that still available?
Old 04-22-2008, 08:34 AM   #6
Mint68
Mint68's Avatar
Re: Center Hump
I would go with silicone, it is super cheap and you can get it anywhere.
Mint68 is offline   Reply With Quote
Old 04-22-2008, 08:46 PM   #7
jhow66
jhow66's Avatar
Re: Center Hump
Rope style body caulk at NAPA.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
