Old 04-20-2008, 07:38 PM   #1
tx71smallblock
tx71smallblock's Avatar
oil pan not coming off
hey guys, i was going to change the gaskets on the oil pan the other day and after i got all the bolts off i relized it was hitting the flywheel and cant come out. this is the first time i have done this when the engine is in the truck. How do you get it out?
thanks ahead
cody
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 04-20-2008, 07:57 PM   #2
cdowns
cdowns's Avatar
Re: oil pan not coming off
you need to have the motor jacked up 3-4" for you to drop the pan enough to clear the oil pickup out of the sump
Old 04-20-2008, 08:16 PM   #3
tx71smallblock
so i have to completely unbolt the engine and jack it up
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 04-20-2008, 08:28 PM   #4
jhow66
jhow66's Avatar
Just the side mounts.Watch yourfan blade so that it does not hit rad.Everything else will move enough. Slow and easy. Jack off the front balancer.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-20-2008, 08:29 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I think you only need to do the motor mounts. Be careful where you jack it up.
This was my turning point when I ended up pulling the motor....
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-20-2008, 08:31 PM   #6
Sport/Truck
Sierra Grande Club
Make sure it cant slip off while your working on the pan, it might be near impossible to jack it up while your arm is crushed under the motor.
s/t
Old 04-20-2008, 08:33 PM   #7
tx71smallblock
front end is down to bare timing chain so no problems there, where should i put the jack?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 04-20-2008, 08:40 PM   #8
Arad68
Trucks N Tranzams
Arad68's Avatar
If have to, rent or buy an engine hoist. They aren't that expensive and much safer. If you jack it up by the balancer you may damage it to the point that you will get an engine vibration or worse.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 04-20-2008, 09:03 PM   #9
70GMCer
70GMCer's Avatar
Here ya go.....
http://67-72chevytrucks.com/vboard/s...91#post1487791
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-20-2008, 10:53 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
while I know jacking the engine up by the ballancer gets done all the time, that's a LOT of weight resting on the end of the crank. I would rent/borrow the hoist.
Old 04-20-2008, 11:12 PM   #11
cdowns
cdowns's Avatar
the engine hoist sounds good till you're under the truck trying to change the pan and you have to deal with the stabilizer legs/ i prefer undoing the towers from the frame carefully jacking on the oilpan (block of 2x10 then you take a couple of short pieces of 2x4 and place between frame rail and towers and the oilpan will come right out//thats the way the chevy service manual describes how to do the job
Old 04-20-2008, 11:29 PM   #12
Billla
Billla's Avatar
Originally Posted by 70GMCer View Post
that's the way I've always done it when I had to. Nice write-up; should be a FAQ!
Billla is offline   Reply With Quote
Old 04-21-2008, 02:28 AM   #13
Arad68
Trucks N Tranzams
Arad68's Avatar
I've never had a problem with the legs on my hoist. They are splayed. The method with the wood sounds great too.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 04-21-2008, 05:05 AM   #14
airdale94
airdale94's Avatar
I got mine out by undoing the trans. mount and jacking up the trans.
airdale94 is offline   Reply With Quote
Old 04-21-2008, 05:35 AM   #15
Sport/Truck
Sierra Grande Club
Thats how mine started a year ago, but I decided to yank the motor when I couldnt drop the oil pan. After the pan is off you might as well put in a fresh oil pump and rear main seal.
I was going to put fresh gaskets and new valve seals while the motor was out when I found a broken valve stem.
I'm still pulling things apart to this day.
I have everything ready to go back in as soon as my fire wall is painted.
s/t
Old 04-21-2008, 06:01 AM   #16
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
I just took off one motor mount, took a small bottle jack in between the exuast manifold and the cross member, and that gave me enough clearence to get the pan out.
It rocked the motor over with no problem.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
