04-20-2008, 10:30 PM | #1 |
Finally a transmission
I finally found a 700r4 tranny. I have to go pick it up tonight and then I open her up and check out the guts. I ordered the lock up kit / wiring kit on line. Finally after three months I might get this project to move...
04-20-2008, 10:39 PM | #2 |
Chasin' the Dream
Re: Finally a transmission
Sweet! I'm still waitin to find one AND have the money for it at the same time. Seems its always one or the other here.
Jerry |
04-22-2008, 02:39 AM | #3 |
Too many projects
What are you using for a lockup kit and TV cable?
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
04-22-2008, 03:42 AM | #4 |
I am using the EZ TV cable system from Bowties Overdrive. I also will probably using their wiring kit. I found another type of kit that uses fluid pressure for the actuator, but I haven't found anyone who has tried that one yet. I guess I'll stick to the one I know people have tried.
04-22-2008, 05:10 AM | #5 |
I just pick this 700r up on saturday at pick n pull for under $100.I was just going to give early classic a call and talk to them about there 700r4 conversion kit.it looks like it come with all the parts that I need.Do you guys think that I can put the 700r trans in with the stock crossmember ?
04-22-2008, 05:28 AM | #6 |
I just measured everything up and I'm using the stock cross member
