Old 04-21-2008, 01:44 AM   #1
SeanPaintsFlames
SeanPaintsFlames's Avatar
383 stroker
I found a 383 stroker on craigslist that the guy said was rebuilt 200 miles ago, but started to pour oil from the valve cover filler hole. He's selling it super cheap, but me being a painter and not an engine mechanic; I want to make sure this is something simple to fix or adjust, or whatever.
Why would a motor do this, and what needs to be repaired? Thanks!!!
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 04-21-2008, 02:02 AM   #2
joe231
joe231's Avatar
Re: 383 stroker
sounds like possibly blow-by, caused by rings not seated properly, bad rebuild, or worn out. did he break-in the engine?
CHEVY ONLY
Old 04-21-2008, 04:42 AM   #3
Billla
Billla's Avatar
Re: 383 stroker
Be careful buying a "just rebuilt" engine; if it was such a great build, why is he selling it - and especially "super cheap"? Look over all the records - he has all the reciepts, right?
I can't even imagine what would cause oil to "pour" from a valve cover.
Pass.
Billla is offline   Reply With Quote
Old 04-21-2008, 04:23 PM   #4
greg64
greg64's Avatar
Re: 383 stroker
I'm thinking corners were cut on the rebuild, and the whole engine hasn't turned out well. So, the current owner wants to unload it, instead of pulling it apart again. Now, maybe there's only a problem with the lifters and way too much oil is being pumped up to the top end.
Trouble is, you'd have to do a number of tests and pull the engine partially apart to be sure.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-22-2008, 07:25 PM   #5
SeanPaintsFlames
Re: 383 stroker
boo
