Will 15's still work?
So I did the whole disc brake converion on the 69 and then realized (after I bought new tires) that the old 15's tend to rub on somthing and don't work too well. I was wondering if aftermarket 15's will work with disc brakes. I just want to avoid buying new tires for the ol' beast.
69 shorty w/ 67 front clip ![]() |
its all about the +6 inches
Re: Will 15's still work?
if you went with 6 lug disk brakes, then you'll need to get 6 lug wheels off a 4X4, or spacers, which may be illegal in your area.
Nothing to see here.....
![]() Join Date: Jun 2007
what rims do you have now and what rims are you thinking of??
I have 'Vette Rallyes on my conversion, and they just barely fit. It's the wheel cross section that must be taken into account.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Rottenwood Garage Member
Drum brake wheels wont work on disc brake trucks without spacers....they rub on the calipers. You will need spacers or rims for disc brake vehicles
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 04-21-2008 at 04:17 AM. |
this is the cleanest photo I have of the rims.the PO told me they are from a S-10 blazer??
I wasn't planning on getting my "official" rims until after the truck is painted so i was thinking about getting a pair of the Cragar cheapos (the all white ones) in the mean time.
a couple of the board members have those rims. they are off mid eighties burbs or special edition trucks (i.e. Heavy Half).
those actually should work with disc setups. anyone else thinking the same thing?
Right you are tcb. They should work no problem, and if you polish them, they can look pretty decent-ish.
If they are rubbing, I would imagine it is just a little bit. Personally, i think I'djust take a grinder to the caliper and remove a little metal. Done it a million times before. |
Ok thanks y'all. they do rub just a bit so as to be anoying and not really grind too bad. The only real problem is when i turn all the way to the right or left they pretty much lock up.. will a grinder take care of that mess?
![]() Join Date: Feb 2004
Hey lets see them bufffed out.
We are picture hounds here on this board.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Too many projects
The turning and grinding could be the wheel hitting the LCA due to dropped spindles. I have this problem with my spindles when I converted to discs, now I just don't turn lock to lock.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
a little grinding action on the lca and your gold.
