Old 04-21-2008, 04:22 AM   #1
LEEVON
Moderator
LEEVON's Avatar
Lower ball joint stuck suggestions please..
I am trying to remove my coil springs because my truck has a 2" lean and the passenger side lower control arm won't budge. I've done this before with ease many times, but this one is being a PITA!
I've got the truck on jackstands, backed the castle nut off the ball joint, placed jack under LCA and lowered but it's stuck. Used pickle fork, big hammer, cuss words, nothing will budge it. I also tried jacking the UCA to let the spring pressure push the ball joint out but no joy.
Anybody have this happen, Any suggestions?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-21-2008, 04:35 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Lower ball joint stuck suggestions please..
I've had to put a small bottle jack in there once in a road side repair (spindle replacement).
Old 04-21-2008, 04:52 AM   #3
jwn1975
Ive had to beat the SH&T out of mine. Bigger hammer. may use slight heat as well.
jwn1975 is offline   Reply With Quote
Old 04-21-2008, 06:13 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I beat on one side of mine for about 3 hours over a 4 day period before it finally came loose.Got the lower loose then had another 1 to 1 1/2 hours in the upper.The other side I hit twice and both popped loose.Use the biggest hammer you can hit accurately with.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-21-2008, 06:21 AM   #5
LEEVON
Moderator
LEEVON's Avatar
I think I'm gonna try the bottle jack trick tomorrow...
Old 04-21-2008, 06:31 AM   #6
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Make that puppy cry uncle with a little heat! PB Blaster never hurts, either. Not at the same time, though!
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 04-21-2008, 07:04 AM   #7
Painter D
Painter D's Avatar
If you have access to an air hammer you might try that ,with a ball joint seperator end on it
Painter D is offline   Reply With Quote
Old 04-21-2008, 09:14 AM   #8
leddzepp
Moderator
leddzepp's Avatar
I used a C-Clamp press from harbor freight tools to get mine out. Beating on it more or using a picklefork will not work, it needs to be pressed out. The bottlejack trick will work as well.
leddzepp is offline   Reply With Quote
Old 04-21-2008, 03:27 PM   #9
70GMCer
70GMCer's Avatar
All above ideas......& use "Bigger Cuss Words".......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-21-2008, 04:15 PM   #10
Longhorn Man
ledzep... he's trying to seperate the ball joint from the spindle.
Old 04-21-2008, 05:08 PM   #11
LONGHAIR
While it is hard to get swinging space in there.....I find the best way for a really stubborn one is the "double hammer". You 2 "fairly big" hammers, nothing crazy, you still have to swing one of them.
What you do is have someone else hold one of the hammers (preferably the bigger one) against the side of the spindle next to the hole where the tapered shaft comes through. Then you swing the other hammer and hit the opposite side, "smashing" into the sides of the "hole".
This is not the right spindle, but the idea is the same.
LONGHAIR is offline   Reply With Quote
Old 04-21-2008, 05:18 PM   #12
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I've also had good luck just hitting it there with a hammer, they seem to just pop out. I'm going to try the double hammer idea next time! Those forks just seems to destroy the boots etc.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-21-2008, 05:33 PM   #13
LONGHAIR
Oh yeah, I am very against the stupid fork thing. They destroy the boots, how could they not?
Old 04-21-2008, 08:48 PM   #14
1967C20
Junior Member
1967C20's Avatar
This is what I did on mine. I took apart a heavy duty brake drum puller, put a nut between the screw of the puller and the ball joint stud, and turned it using an impact gun. Heat, penetrating oil, whacking with a small sledge, and turning the puller with the impact gun eventually broke it loose. Resistance is futile!
"A man's got to know his limitations." - Dirty Harry
_______________________________________________
1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker
1967C20 is offline   Reply With Quote
Old 04-22-2008, 05:15 AM   #15
rick0312
rick0312's Avatar
I had a similar problem when I was removing my outer tie rods. The thing was just frozen in there. I tried everything...PB blaster, BFH, Pickle fork and heat. I eventually had to cut it off and drill out what was left behind. I just took my time and kept increasing in drill bit size until i cleaned the hole out. Be carefull because the ball joint hole is tapered just like the tie rod.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 04-22-2008, 08:26 AM   #16
Mondo
Mondo's Avatar
Finally took the lower A arm off the truck (with spindle still on) and took it to a shop. I didn't ask how they did it, wasn't sure I wanted to know...
Mondo is offline   Reply With Quote
Old 04-22-2008, 09:27 AM   #17
leddzepp
Moderator
leddzepp's Avatar
If removing the ball joint from the spindle, Longhairs method is the way to go. I was talking about removing the ball joint from the LCA.
Old 04-22-2008, 04:41 PM   #18
Shane
Shane's Avatar
The perfect tool for this job ... less than $10 and it's from Harbor Freight too
Shane is offline   Reply With Quote
Old 04-22-2008, 06:59 PM   #19
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I use a big 'ol bolt, nut and socket to fashion a makeshift ball joint press. Hold the bolt head with one wrench, and turn the nut with the other and you have yourself a removed BJ. It smashed my knuckles when she broke free, but the boot stayed intact and all that jazz.
Some paint for ya'll (flip for upper ball joint):
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-23-2008, 04:17 AM   #20
PanelDeland
Shane, that looks just like my favorite Ball joint tool!!!Came from the same place too.
Old 04-23-2008, 05:03 AM   #21
LEEVON
Moderator
LEEVON's Avatar
yeah, yeah...I'm the king of BFH and this one won't budge. I ended up just popping the spindle from the UCA's.
Old 04-23-2008, 09:23 AM   #22
leddzepp
Moderator
leddzepp's Avatar
The easiest way to remove/install coil springs is to use a spring compressor. Then you do not need to mess with the spindles and ball joints.
Old 04-23-2008, 03:11 PM   #23
Stoney
Farm Truck
Stoney's Avatar
Put the wheel back on and slowly let the truck down, the weight of the truck will break it loose.
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 04-23-2008, 11:36 PM   #24
Shane
Shane's Avatar
So how are you gonna get the compressed spring out of the pocket if you "don't mess with the spindles or ball joints" ???
Old 04-24-2008, 01:26 AM   #25
jrb71c20
jrb71c20's Avatar
Magic...sheesh Shane where you been man, a cave?...
93 Sonoma 2.8/5spd
75 Malibu Classic 350/350
If it don't have round headlights and a carb, I don't trust it!
jrb71c20 is offline   Reply With Quote
