Old 11-02-2002, 05:35 AM   #1
SeAnScHeVy
Local Punk
How much lower can i go? lowering help!?!
I just installed my 3 inch drop springs in front and 4 inch drop in the back... it sits nice and level but it just isnt low enough. what can i do to get the body to sit closer to the ground??? thanks for any help guys, Sean
SeAn ThE cHeVy GoD
SeAnScHeVy is offline   Reply With Quote
Old 11-02-2002, 09:30 AM   #2
crazy longhorn
Fabricate till you "puke"
A 3" drop spring is really pushin the limits of the front end geometry, & i would reccomend a 2 1/2" spindle + a 2" spring up front as max drop. At the rear, if you have a 4" drop coil, you can add a 1 1/2" block to keep your level stance. You will also need to add a frame notch,& an adjustable panhard bar(track locater), to center the rear end. If you want SLAMMED, best bet is talk with the "bagged guys". Good luck.....crazy AL
crazy longhorn is offline   Reply With Quote
