Old 04-21-2008, 07:06 AM   #1
streetstar
streetstar's Avatar
Denied ! (ac still not cold)
Wel, i put some r-134 service fittings on my compressor and voila! Low side pressure is at 60 and its still not getting cold
Anything else that can go wrong with these things?
I have a giant York compressor that does not appear to have a clutch on the front, so i dont know if its engaging or not, or if its always engaged ---
for now its lookin like 2 wasted cans of refrigerant
pic of compressor ---
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-21-2008, 07:35 AM   #2
Pont406
Re: Denied ! (ac still not cold)
All r134 systems that I seen have about 25-30psi on the low side. Almost sounds like there is a restriction somewhere.
Pont406 is offline   Reply With Quote
Old 04-21-2008, 01:23 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
28 # is the freezing point for R-134A . In the picture there is no belt . Also looks like there could be a wiring problem . It appears the clutch wire has a wire nut on it . Might make sure you have power to the clutch . For safety reasons always make sure you monitor the high pressure side of the system as well when charging .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-21-2008, 05:00 PM   #4
streetstar
streetstar's Avatar
Originally Posted by hotrod 80 View Post
28 # is the freezing point for R-134A . In the picture there is no belt . Also looks like there could be a wiring problem . It appears the clutch wire has a wire nut on it . .
its an old pic -- it has a belt now -- i just posted the pic to show the type of compressor
did not know about the 28# freezing point -- the 12-134 conversion instructions stated to pressure it to 50-55# at 80 degrees outside air.
Old 04-21-2008, 05:05 PM   #5
72BLUZ
72BLUZ's Avatar
you have been giving proper info. check you pressure switches, checked fuses and relays. get the low side between 30 and 40 psi and the top side should take care of itself. remember dont use as much 134 as you would 12
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 04-21-2008, 06:05 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
The 28 # s is directly from the pressure to temperture chrt for 134 A . anything below that and the evaporator will try to freeze . to much suction pressure will result in high suction super heat or liquid flood back . Your compressor cannot pump liquid .
Also on top of the liquid line filter/drier ( passenger side fender well ) is a sight glass . You may have to clean it with a rag and maybe add a drop of oil to the glass , but you should see refrigerant moving through this glass . If you have a fixed restricter you may see some vapor in it when fully charged . Go by your pressures . If discharge gets above 275 and you still have low suction you more than likely have a problem . If it is an expansion valve system that has been open for some time it may have a stuck valve due to moisture .If i am not mistaken the front of that compressor will be spinning when the clutch is engaged .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-21-2008, 10:11 PM   #7
Andy4639
Old member
Andy4639's Avatar
The dryier is on the fender well can you see liquid running through it or is it just sitting there. I wouldn't trust those two radiator clamps on the black hoses either. Quick way to check compressor is run a jumper to the compressor straight to the battery see if it comes on. Then you know there is a problem in your wiring some place.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-22-2008, 02:22 AM   #8
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
On a York, if the middle of the pulley is turning the clutch is engaged, if it's stationary it's not. I run a 209 for my suspension.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
