Camaro front clip installation
Here somthing I though might be of intrest. It's a new product that No Limit sell's for clipping camaro's onto 1955 to 1959 Chevy trucks.
Here's the link. http://www.nolimit.net/prodinfo.asp?number=D%2D101 TECH DVD 55-59 CAMARO CLIP Item Number : D-101 Unit Price: $35.00 Detailed Description This DVD shows you how to graft a 74'-81' Camaro front clip to the frame rails of your Chevy truck. It includes the installation of all IFS suspension pieces, the motor mounts, and the transmission mount. In addition, it also details the removal and replacement of the front bumper and radiator core support mounts along with boxing the front frame rails.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 04-21-2008 at 08:39 PM. |
![]() Join Date: Feb 2004
Re: Camaro front clip installation
Way Cool, thanks for the link
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
I have their VHS version of that and was pretty disappointed in the quality of the video. Not only was it not a very professional presentation but the detail regarding how the core support mounting brackets are installed was completely glossed over. While it does provide good information it is very difficult to watch and could have been much better.
Possibly they upgraded it now that it is on DVD. I would say it is almost worth the money they charge but their shipping costs were excessive. I was able to get them to cut that in half by calling them and discussing it with them. After viewing the video I gave them some feedback on the missing details and they acknowledged it was pretty thin on the core support brackets but that I was the first person to give it a somewhat negative review. |
#4 | |
polishing a turd
i'm willing to bet it is th same one, just now on dvd, because who owns a vhs anymore?
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
#6 | |
Guest
Posts: n/a
I deviated somewhat from their method of bending the frame out to fit the clip. Instead of tapering the sides of the camaro clip I held my cuts where the clip would fit right inside the frame exactly and made a nice rounding transition at the end of may chamfer close to the a-arm towers. I personally think this looks just as good and you dont have to heat the frame to spread it apart. My method also allows the clip to make better contact with the frame instead of only making contact where the tapered clip meets the frame. This also allows you to weld the clip on the inside of the frame as well as the outside before boxing in the inside of the frame around the clip. I have seen far better methods than the one they use for re-attaching the front frame sections ahead of the clip. The cleanest method I have seen is on Cal's frame and that is how I will do mine. You can still use the postioning instructions shown on the DVD to do this or any other method. All-in-all the DVD is worth 35 bucks. |
Here is a link to a pretty well done tech article on the H.A.M.B. that details the swap step by step.
http://www.jalopyjournal.com/forum/s...ht=Camaro+clip It leaves a bit more subframe than some I have seen but it is strong and the instructions are easy to follow. I would say it would be great for a daily driver truck that was going to see a lot of miles but is not the cleanest looking install. I looked at your pages on the build of your truck and that is probably the cleanest subframe installation I have seen in a long time. http://67-72chevytrucks.com/vboard/s...d.php?t=162816 This, folks is what you need to do if you want a show winner. Last edited by mr48chev; 05-20-2008 at 12:55 AM. |
I am interested in see some pics of trucks with clip done according to video. I have video and it says to use stock axle centerline. Has anyone used video to do clip? Are you happy how the front wheel fits wheel opening? Also video states to measure from welded in reference point to shock eye holes to line up clip but says nothing about squaring the shock eye holes to frame. It just seemed to me you could get clip not parallel to frame pretty easy by just measuring forward with out squaring things. Any thoughts?
polishing a turd
you NEED to cross measure also to square the clip with the frame
I'll jump in with my opinion. I would NOT use the factory axle centerline as your new target. My preference is to move the new one forward 2", and it is much easier now than later. You can always cut your truck frame shorter...
I say this after having cut apart a subframe job on a '55 to add 2" to make the wheels look better in the front fenders. I ended up rebuilding the frame where the splice was so I could blend it better, since I had to make up the 2" of missing frame anyway. |
#11 | |
Guest
Posts: n/a
Since your talking about camaro subframes maybe somone can help me out.I have a 56 with a front steer clip,what are u guys using for a radiator.When i bought my truck the rad was rigged in and will have to be made to fit or get stock one.Also will a stock rad clear the steering box.
#13 |
I used a stock radiator bolted into the stock radiator support. When your clip was installed it should have the front frame rails welded on to the front of your clip. Your stock radiator should not hit the steering box, it's close, but it should clear.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#14 |
Sweet but hows that stock rad cool,i have a big block getting bilt will that be enough,i did find a griffin alum for stock support but its 700.
#15 |
Were I live it gets over 100 degrees and it runs about 190 with a 350 small block.
#16 | |
Here a link for a 1955 56 57 58 59 Chevy Truck Aluminum Radiator on e-bay. http://cgi.ebay.com/ebaymotors/PRC-1...8962QQtcZphoto
#17 |
Thanks for the info,i'll have to send you some pics of mine very similar to yours.camaro clip,with custom frame back,air ride,suicide doors,shaved and smoothed everything.I dont even know how many hours i have into this body,making doors and hood fit
#18 |
mxer.... I run a big block that is tweaked some with a stock style radiator that is a 4 row... Truck runs between 180-190 all day long...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
#19 | |
