04-22-2008, 01:49 AM | #1 |
rally wheels
I have a 69 GMC Longbox and I want to put on some rally wheels it has a 6 bolt pattern. what year rallys fit and are they the same as the 4x4 rims. because some of the pictures I see they look like 4x4 wheels on a 2wd truck and is there other center caps to use any help would be great I would like to
put 8" on the front and 10" on the rear. possible picks and rim info would be great. thanks |
04-22-2008, 02:23 AM | #2 | |
Re: rally wheels
If you want wider than that, you'll need to find someone to widen them (Eric Vaughn Wheels) or purchase them from the aftermarket (Wheel Vintiques).
04-22-2008, 02:51 AM | #3 |
I have a radical idea!
Re: rally wheels
I have 15 X 8's on the front rear with a 1.5" spacer on the rears on my truck. The spacers and wider tires on the rear kinda give the illusion of wider rims.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-22-2008, 04:33 AM | #4 |
Re: rally wheels
Have you considered reproduction Vette rally wheels in 6 bolt?
Here is a set on eBay for $350. http://cgi.ebay.ca/NEW-CORVETTE-VETT...QQcmdZViewItem They come in 6 bolt. I have a set on my 69 GMC and I believe 67Chevyredneck also has a set. I paid $400 for mine shipped to my door in Northern Canada and that is with caps and trim rings. When I was looking a set of used rally wheels with caps and rings were about $200. They are 15 X 8 and the tires I have are P235/75/R15.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
