04-22-2008, 02:01 AM | #1 |
Madmandav
Need help with rear sway bar
Does anyone know for sure the correct way of installing one of these. It is from CCP. As far as I can tell the bushing shaft should be straight but what is the best method of getting it that way. I already had to shave the bushings down just to get the dang bolt on it to begin with and as you can see it is just barely on there. The bar bushings are not mounted to the trailing arms just yet, need to get in the right position first. Any advise?
I must be crazy, that's what the voices in my head keep telling me. Project FROSTBITE http://www.67-72chevytrucks.com/vboa...d.php?t=280249 http://www.67-72chevytrucks.com/vboa...d.php?t=287407 '72 Chevy longbed '70 Chevy longbed (million pieces)(FROSTBITE) '79 Monte Carlo '07 Chevy HHR '00 Yamaha V-star '05 Monte Carlo SS Supercharged |
04-22-2008, 02:24 AM | #2 |
Active Member
Re: Need help with rear sway bar
It should be straight up and down, you will have to drill your own holes
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
04-22-2008, 02:29 AM | #3 |
Madmandav
Should I push the bar back or should I raise the rear to get it straight? Also won't it put alot of strain at the mounting for the long bushing bolt? That thing doesn't look very beefy.
I must be crazy, that's what the voices in my head keep telling me. Project FROSTBITE http://www.67-72chevytrucks.com/vboa...d.php?t=280249 http://www.67-72chevytrucks.com/vboa...d.php?t=287407 '72 Chevy longbed '70 Chevy longbed (million pieces)(FROSTBITE) '79 Monte Carlo '07 Chevy HHR '00 Yamaha V-star '05 Monte Carlo SS Supercharged Last edited by Madmandav; 04-22-2008 at 02:30 AM. |
04-22-2008, 02:51 AM | #4 |
67-72 Addict!
Are you planning on shock relocators?. Your shocks look like mine- ANGLED!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-22-2008, 02:57 AM | #5 |
Madmandav
No, the shocks will stay the same, stock, the rear is only getting dropped 3'' with new springs.
04-22-2008, 04:31 AM | #6 |
I ran into this same problem with mine. It needs to be straight, but if you lower the front of the bar enough, it looks goofy hanging that far below the trailing arms. Plus, then you need to keep moving it forward to the front of the truck to mount the bracket ahead of the kick up in the frame. I compromised and mounted mine like this-
I figure it still will be better than no bar, and I can definitely tell a difference.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
04-23-2008, 02:41 AM | #7 |
Madmandav
I am thinking I should just change the position of the bracket on the frame?
04-23-2008, 05:50 AM | #8 |
That's what I would do.
04-23-2008, 06:02 AM | #9 |
What about mounting it on top of the trailing arms, or would that interfere with the drive shaft?
edit**** Never mind, I see that it will. However once you put the suspension back on the ground with the bed weight won't it level the bar out some? Personally O would wait and put it on when I had the truck back together with the weight of the vehicle. THat is what I did on our Bel Air. JMHO. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 04-23-2008 at 06:05 AM. |
04-23-2008, 06:47 AM | #10 |
Do you mean "CPP"? I put the front and rear kit on my '72. Will get some photos . You need to have the weight on the truck when installing the rear. They should have come with instuctions. They sure do make the truck much more stable.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-23-2008, 01:32 PM | #11 |
Madmandav
Yes, CPP.
04-23-2008, 05:38 PM | #12 |
70+ ( Old Skool Club )
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-24-2008, 05:41 PM | #13 |
67-72 Addict!
Look here:http://www.classicperform.com/Instru...PDF/CP7401.pdf
Says drill a hole 20" from oval along frame rail and 2" up from edge. Lowered trucks may need to be modified according to directions.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 04-24-2008 at 05:42 PM. |
04-24-2008, 07:05 PM | #14 |
Mounted mine the way 70c10 shows- works great.
04-29-2008, 05:41 AM | #15 |
6072TTA 60-72 Trailing Arms Only Pair I'm using cpp's tube style arms, no provisions for swaybar, I know with minor fabrication this will work, but has anyone done this yet? Don't want to reinvent the wheel if someone already has!
