Old 04-22-2008, 03:41 AM   #1
lowriden58
lowriden58's Avatar
back space on 15x12s..
hey guys, i tried to search and couldnt find much on this. im wanting to run 15x12s in the rear of my 71 but not sure on the bs? anyone know what i should run? i was thinkin 5.5 but i did run across 1 thread and the guy said he was running 7.5" . i just need some confirmation i guess
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 04-22-2008, 05:19 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: back space on 15x12s..
5.5 works for 10s, so 7.5 sounds right. You will have to mini-tub...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-22-2008, 01:59 PM   #3
With 12s I`d think you`d need to worry about offset as well as back space.Are you trying to fit these on a no-cut frame/standard width axle?I ran 12s on a pro-street truck that was back 1/2ed and tubbed.I wanted that and ran the biggest tire I could.I`ve never looked at 12s fitting on a stock body/frame.My guess is they won`t fit.Maybe guys are doing it.We`ll see what answers you get.Just telling what I know.I like deep dish.
Old 04-22-2008, 02:18 PM   #4
70c10
67-72 Addict!
70c10's Avatar
I agree. If you don't wan't to mod, I believe we only have about 14" max from frame to edge of wheel opening. If you run a 12" rim that leaves only 1" of rubber on either side of rim to stay tucked and that's rubbing the frame. If you go with a 10" rim you have 4" to play with as far as backspace and offset.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-22-2008, 03:34 PM   #5
lowriden58
lowriden58's Avatar
yeah this is on a stock frame and axle. of course it will be mini tubbed just trying to get the largest tire/wheel combo in there so i can get some traction. ive see pics of guys running 12" wheels before matter fact someone posted a evilbay auction yesterday on here with a "riced" out chevy.
Old 04-22-2008, 06:35 PM   #6
PA-IndianRider
PA-IndianRider's Avatar
There is another thread on this forum that is discussing wheel/tire with I think you would like to read:
http://67-72chevytrucks.com/vboard/s...d.php?t=288044
Hope this helps... as you can see for reading this info and the info found here there is a lot "different" views on what works and what doesn't.
So the more info we get the better.... thanks
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 04-22-2008, 06:47 PM   #7
lowriden58
lowriden58's Avatar
thanks, BTW weld makes 15x12's and 15x14's for our bolt pattern.. i believe the largest BS they offer is 7.5
Old 04-23-2008, 07:07 PM   #8
PA-IndianRider
With GM rally wheels (8") & 9" wide Mickey Thompson 60 series tires there is still 5" of clearance between the back side of rally wheel & the back corner of the trailing arm (which could be trimmed for more clearance).
This setup has the tire just past the fender (wheel well) by less than an inch. So unless you don't mind the tire sticking out of the wheel well the "front spacing" needs to stay the same as this rally wheel.
The "front spacing" & "back spacing" on the 8" GM rally wheel I have is almost "equal" (4 " each) so when comparing wheel/tire combos "do the math".... for in most cases once you "mount them they are YOURS" !!!!!
John aka "Milner"
