Old 04-22-2008, 10:11 AM   #1
rn2fine
rn2fine's Avatar
Help - AC Prob
The AC in my 72 is working great except when I turn the fan switch to high. Thee are 3 fan positions. The first two work OK. I assume maybe the third position trips a relay with direct current to the battery. If so, where might the relay be located?
Thanks !!!
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 04-22-2008, 10:43 AM   #2
JimKshortstep4x4
Re: Help - AC Prob
The relay is located on the right side of the inside box close to the lower kick panel vent. You can get to the relay without removing the glove box but it can be seen better with the glove box removed. Here is a picture of the unit with the glove box removed and the relay can be seen on the right where it is mounted upside down.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
