04-22-2008, 03:37 PM | #1 |
rolling stock
Hey guys I have a 72 K5 mostly original, I was going to make it over as a 2wd. Does anybody know if axles out of a 70's pickup will slide in and work with the original pumkin on the blazer...Thanks Ed
04-22-2008, 07:09 PM | #2 |
Can't wait to retire!!
Re: rolling stock
Sorry I can't help with your question, but welcome to the board from Michigan.
I'm sure one of our knowledgeable members will pop in and give you the correct info.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 04-22-2008 at 07:10 PM. |
04-22-2008, 07:39 PM | #3 |
Re: rolling stock
I am not sure about the axles fitting into a housing, but you should be able to get a complete rear assembly hub to hub for $100 to $150 and bolt it right in.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
04-22-2008, 08:55 PM | #4 |
SKINNY TIRES RULE!
Re: rolling stock
Welcome to the board from Seattle. Post some pics when you get a chance and be sure to document the transformation.
I believe you can put stock 5 lug axles into the stock rear end. Here's an article on doing a conversion. http://www.sporttruck.com/techarticl...ion/index.html
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-22-2008, 10:46 PM | #5 |
Re: rolling stock
BOUNCYTRUCK.. Thanks for the 2wd convertion link that answers alot of my questions I have a doner frame/rolling stock that should work, I was hoping to leave the leaf springs. But it would be better to go all the way and make it right....
04-23-2008, 12:31 AM | #6 |
SKINNY TIRES RULE!
Re: rolling stock
You can use the leafs. Board member LivRat has converted a dozen or so over the years. He said he's done both leaf and trailing arms. I'd go with tailing arms or a 4-link system, especially if you're gonna bag it.
If I ever have the time, my '72 might get converted. I'd love to see you're process.
04-23-2008, 04:33 AM | #7 |
Re: rolling stock
As with everybody else too much going on not enuff time. I have a lot of parts to sand blast and (maybe powder coat) try something new. I have a running 62 panel truck that I restored 15 yrs ago now needs repainted after body work. I hope to get back on the Blazer this year, 2 yrs ago new poly gas tank, electronic distributor, demon 650 carb crossfire manifold look nice but it doesn't run any better. The beat goes on....
