04-23-2008, 02:13 AM | #1 |
Help with Fleetside box disassembly
Wondering if there is any cutting involved in disassembling a 67-72 fleetside box?
If your not living for something, your dieing for nothing... |
04-23-2008, 02:21 AM | #2 |
Re: Help with Fleetside box disassembly
Don't know about fleets but step sides has some spot welds at least one I had did.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-23-2008, 02:29 AM | #3 |
The fleetsides with a steel floor ( I don't know about the wood floor models) have a couple of welds in the back that need to be cut out.
A cut off wheel in a die grinder works pretty well for that. Other than that, it's just bolted together.
"Negative people always seem to have a problem for every solution" |
04-23-2008, 02:36 AM | #4 |
Madmandav
Just a weld at the bottom of each tailgate post.
I must be crazy, that's what the voices in my head keep telling me. Project FROSTBITE http://www.67-72chevytrucks.com/vboa...d.php?t=280249 http://www.67-72chevytrucks.com/vboa...d.php?t=287407 '72 Chevy longbed '70 Chevy longbed (million pieces)(FROSTBITE) '79 Monte Carlo '07 Chevy HHR '00 Yamaha V-star '05 Monte Carlo SS Supercharged |
04-23-2008, 02:56 AM | #5 |
TOTY 2006
two welds per side for rear panel where it meets the rear stake pocket towers.(4 welds total) Cutoff wheel or can use the sawsall....
04-23-2008, 04:49 AM | #6 |
69 C10 LWB GM 350 crate motor, 3.73 rearend |
04-23-2008, 01:08 PM | #7 |
All the info you guys have provided is awesome......Thanks a bunch.
