Parts ID
Well i need some help again. I would like to know if what these are. The carrier is supposed to be something like a posi, the guy i bought my truck from kept reffering to it as a "tick tock type posi". I would like to know what it is, and if it is worth putting behind my 250 and 3spd with 3.73's (currently an open diff)
The second thing is a GM 3spd of somesort. ![]() ![]() ![]() ![]() I can go snap more pics if you guys need, or grab number off of them if you guys need. Thanks for the help. |
The Older Generation
Re: Parts ID
Don't know what the "posi" is. The tranny is a long tailstock three speed. Probably from a six cylinder. LockDoc
Re: Parts ID
Thanks for the reply. What i was trying to determine is whether the tranny is worth keeping or if it is destined for the scrap pile. It's ALOT smaller than the 3spd in my truck.
Re: Parts ID
the posi is whats called a gov style posi that was put in to later style trucks i.e 73-80 or what ever year they stopped the 12 bolt hope that helps and i think about 400hp is there limit so you should be good.
Born Psycho
![]() Join Date: Feb 2001
Re: Parts ID
the carrier looks to be a "gov lock".
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Re: Parts ID
I believe the trans. is a non-syncro trans. early GM.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
Re: Parts ID
I should be good for HP if there is a 400hp limit. MY little 6 isnt stock, but it sure isn't 400hp. This is going to sound like a really dumb question, but i don't suppose i could take out my current carrier, and swap the ring gear over with whatever shims are in it now straight up, and not touch the pinion assuming my gears are in good shape. If not (which I'm assuming is the answer) where does one go about getting shims? I understand the general concept of gear shimming, and have read the guide on Richmond gear's site.
Re: Parts ID
The shims if they are in good shape should still work,the ring gear can be swapped as well you just need to make sure that the contact pattern is correct and the carrier back lash is within specs.
Re: Parts ID
But if i have to reshim, and i were to need more shims where would i get them?
Re: Parts ID
you can order the carrier/gear install kit from jegs or summit or any rearend parts dealer.
Re: Parts ID
Now the question is is it worth my time and effort to swap in?
Re: Parts ID
Two tire smoke is way cooler than the one wheel squel any day i say go for it.
#13 |
Re: Parts ID
#14 |
Re: Parts ID
#15 | |
Re: Parts ID
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#16 |
Re: Parts ID
#17 |
Re: Parts ID
yeah you'll be fine, he just misunderstood the question... just put some paint on the ring and spin it and check the wear pattern.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
#18 |
Re: Parts ID
#19 |
Re: Parts ID
Sorry adout that.
#20 |
Re: Parts ID
