11-02-2002, 03:10 PM | #1 |
key/starting trouble
i've noticed this.... when it's cold out and the truck hasn't been ran...
when i turn the key the engine doesn't start... but everything else is on as normal... i have to turn it a few times before the starter kicks in.. sometimes i have to do it more then others... any ideas? ignition, starter, wiring... gimme some input please and thanx |
11-02-2002, 03:30 PM | #2 |
Have your battery checked. Cold weather affects the cranking capabilities of batteries. You may have enough voltage to run lights and radio, but not enough current to initiate the starter.
11-02-2002, 11:00 PM | #3 |
Starter probably just needs a new bendix. Does the starter run but just not engage? Hope this helps.
11-02-2002, 11:45 PM | #4 |
I Got My Engine!!!!!
yeah i would just check the battery first, and maybe the connections but the fact that you say it only does it on cold days make me think otherwise, but thats just a suggestion
F.O.R.D. "F*cked Over Rebuilt Dodge" -+-+-+-+Cameron+-+-+-+- 1987 GMC HIGH SIERRA LWB 1500 32X11.50 383 TBI/Vortec Heads/Intake MSD Ignition Dual Exhaust Custom Pinstriping Sweet interior & stereo http://www.cgalvin29.freehomepage.com |
11-03-2002, 11:01 AM | #5 |
thanx for the suggestions guys...
it was doing that pretty much since i got it. and i thought it was the connectors... so i changed them... and the baterry is fine... it seems like there is a switch or something not engaging somewhere... maybe the shifter is not making solid contact in park... could it be that? on warm days it does it less. and the starter does work fine.. but it's just that i have to turn the key about 5-6 times before it even engages. |
11-03-2002, 07:40 PM | #6 |
Makes me think of the ignitionswitch,wich is located on top of the steeringcolumn.
It's actuated by a rod.When it's warm the rod will expand a little so the switch does it's job.When ist's cold the rod is a little shorter and the switch doesn't switch all the way. You can adjust the position of the switch.But you need to lower the steeringcolumn to get at the switch. I had this problem a few years ago.
*Andre* 1984 C10 SWB, 350/700R4 |
11-03-2002, 08:04 PM | #7 |
Do you hear the starter spinning but the engine is not?
as mentioned before, this sounds alot like a bad bendix which DOES get worse as temps fall. If thats not the case, try moving the gearshift into neutral while trying to start it. If it starts or tries to start when you move the shifter, get yourself a new neutral saftey/Reverse light switch. |
