People know me
205 loose yoke
Ok a little background............
I bought a 465/205 setup from a buddy. I installed it into my 72 blazer with a 8" suspension lift, I have always had vibration coming to a stop, would vibrate the truck quite a bit, I drove it like this for 6 months as my daily driver until just recently I was able to afford a High Angle Driveline cv shaft for the rear. I also had a nasty gear oil leak since I got the thing, Ends up the t-case adapter was cracked at the top of the mounting flange. i pulled it too and had a machine shop weld it up. Today, I finally get everything installed and hop in to check out my ride with the new cv shaft. coming up to the stop sign at the end of my street I got the same nasty vibes as before. I turned around and pulled back into the driveway. I took out the angle finder and the axle yoke is 18* and the driveline is 20* I went to check the output flange and the whole thing moves up and down about 1/8-3/16" so what does this mean? what Am I looking to replace here? It has a fixed flange.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Re: 205 loose yoke
are you talking the front or rear shaft of the t case, just resealed mine, growling noise in 4 wheel, found bad bearing behind front shaft yolk outside bearing, $34 bucks, $25 for complete seal kit back together,
Re: 205 loose yoke
When you get your vibration. Is it when you put on your brakes? If so, it's more than likely just warped front rotors.
