Old 04-23-2008, 05:01 AM   #1
joe231
joe231's Avatar
what the heck is this? 3 speed overdrive?
anyone heard of these???
linky
CHEVY ONLY
Old 04-23-2008, 05:23 AM   #2
kevindtimm
Re: what the heck is this? 3 speed overdrive?
Yes, they are EXTREMELY cool! I used to have one, but the rebuild cost was too much for me (previous owner not too forthcoming about condition)
I would love to get another one, and know a guy locally who hoards them but a T5 is easier/less expensive to repair. If I had to choose? T85N w/OD (this item)
kevindtimm is offline   Reply With Quote
Old 04-23-2008, 05:27 AM   #3
joe231
joe231's Avatar
i had no idea, what is the electrical stuff on it? is it a electric over drive. 3 speed plus over drive, or is 3rd gear the over drive?
CHEVY ONLY
Old 04-23-2008, 06:25 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
3rd gear plus OD. Electric switch for shifting in and out. Shifting was similar to a 2 speed rear on a 2 ton, it would shift after you switched it in and let up off the gas.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-23-2008, 06:33 AM   #5
joe231
joe231's Avatar
wow, that is cool
thanks
the more i hear, the more convinced this tranny is what was in our '66 before my father in law swapped in a 283 and granny 4 speed, wish I knew what he did with the tranny
CHEVY ONLY
Old 04-23-2008, 07:03 AM   #6
greg64
greg64's Avatar
So basically, are we dealing with a 2 speed in the extension housing? Never seen one of these animals....
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-23-2008, 04:35 PM   #7
kevindtimm
3 speed tranny, 2 speeds (1:1 and .70:1).
3000 RPM @ 65mph or
2100 RPM @ 65mph
SWEET!
Old 04-23-2008, 05:10 PM   #8
Rogue 64
Ol' Blue Viking
I have seen Sag 4-speeds with those OD's adapted.
I thought about doing that, but I'm afraid the 327 would twist it all up.
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 04-23-2008, 09:01 PM   #9
rickf
rickf's Avatar
At one time I was looking for one of these, they are hard to find. I found a lot of info on the net, though, e.g.
http://www.jalopyjournal.com/forum/s...d.php?t=249066
One of the things I came across (don't know where it is now) said these overdrives free-wheel when coasting forward. So, e.g. cruising on the freeweay on long downhill you may as well be in neutral, no engine braking. I don't know if that applied to all or just certain models, there are apparantly couple different actual overdrives units used.
rickf is offline   Reply With Quote
Old 04-23-2008, 10:17 PM   #10
kevindtimm
To clarify the 'coasting' bit:
Cable pulled out - normal 3 spd tranny
Cable pushed in:
1) Overdrive enabled (electrically) full engine braking
2) OD disable (freewheel)
You have to have the cable pulled out to go into reverse. Be sure the have the cable pulled out when parking - unless you trust your parking brake 100%
Old 04-24-2008, 02:58 AM   #11
1974k5blazer
Speaking Of This Have You Ever Heard Of A Th350c With Some Type Of Overdrive!
1974k5blazer is offline   Reply With Quote
Old 04-24-2008, 04:09 AM   #12
Rogue 64
Ol' Blue Viking
My brother has 2 Turbo400 with an bolt on electric OD.
One behind the 6.2D, he plans to put in a 1962.
Old 04-24-2008, 04:12 AM   #13
joe231
joe231's Avatar
Cable pushed in:
yes that is the tranny that used to be in the '66 before it was mine, guess I knew more about these than I thought
CHEVY ONLY
