Old 04-23-2008, 05:13 AM   #1
bdydrp97s10
bdydrp97s10's Avatar
where to get 4 speed coumumn bearings at
im thinking about gettingi a 4 speed coulumn, but there is some slop in it.. where can i get the bearings to fix this
bdydrp97s10 is offline   Reply With Quote
Old 04-23-2008, 11:50 AM   #2
JimKshortstep4x4
Re: where to get 4 speed coumumn bearings at
If you are working with a stock non-tilt column then the bearings are the same as the other columns. I believe the bearings are still available from the dealer.
Is the lower spring in place? Without the spring or if it is not adjusted correctly there will be looseness in the bearings.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
