Old 05-07-2002, 11:11 AM   #1
dubie
dubie's Avatar
Post Clutch question when swapping engines
When I go from my inline to the 350, will i have to replace the clutch with a 12"? I was talking with a mechanic buddy of mine yesterday and he figured I should go with a bigger clutch. but I figured if i am staying with the 3 speed tranny, i might as well stay with the one I have. Any thought on this
72 C/10 LWB 2wd
250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-07-2002, 11:16 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I'm not sure what's reccomended, but if I remember right, most v-8s use a 12" clutch, and if I was changing engines, or even pulling an engine to reseal or something, i'd replace the clutch, just because the $$ to replace now makes more sense than pulling the engine again when the old used clutch goes kaput.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
my site:
http://communities.msn.com/Beastonabudget/homepage
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-07-2002, 11:47 AM   #3
okietruck
Post
I recently swapped the I6 for a V8 in my 72 and used the same clutch (stock 10 1/2" diaphram) with no problems. You may have to go to a larger flywheel if you use a 12" clutch. I have a heavy-duty 11" I plan on putting in mine when the time comes.
'72 LWB Stepside
okietruck is offline   Reply With Quote
Old 05-07-2002, 12:17 PM   #4
tom hand
CCRider
tom hand's Avatar
Post
If the clutch is in good shape I would use it,becuase the weak point will be that trans behind a V-8. If anything shows the slightist bit of abuse now is the time to change it.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
