04-23-2008, 05:43 AM | #1 |
Shock question.
Hey all.
I am running airbags on the rear with shock relocators. What is the right kind of shock to run. Can I run the standard shocks or do I need to go with a lowered shock? Wasn't there a post about sizes of different stock shocks that could be used instead of buying the aftermarket nitro, belltech and such shocks? I was working on the rear when and when I pulled the monroes I found out one of them is completely worn out. Can I just re-run what I had (monroes)? I am running the stock style monroes up front with drop spindle and 1" lowered springs. Is that okay? Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-23-2008, 01:37 PM | #2 |
67-72 Addict!
Re: Shock question.
With shock relocators, I "think" you will be ok with stock length shocks.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-23-2008, 05:02 PM | #3 |
Re: Shock question.
Thanks.
Anyone else? Shawn
04-23-2008, 05:21 PM | #4 |
Re: Shock question.
Stock shocks work fine w/the relocation brackets on mild drops (6" or less). They'll get close to the limits of their travel designs w/o the use of lowering blocks if the drop is greater than 6". My 68 swb trucks rear drop was ~8" & used:
Firestone bags bolted directly in place of coils 1.5" CPP lowering blocks Modified stock shock brackets (same as relocation kit) Bolt-in style CPP c-notch Adj CPP panhard bar Off the shelf Gabriel HD gas VST shocks F/R No problems in 5+yrs of the daily grind which included pulling a car trailer.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-23-2008 at 05:22 PM. |
04-23-2008, 05:23 PM | #5 |
Re: Shock question.
Awesome! THat is what I'm looking for! Thanks Scoti!
SHawn
