Old 04-23-2008, 06:35 AM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
3/4 ton -> 1/2 ton conversion..
What all is needed to do this on the front? Can the spindles just be swapped or is it more indepth that I'm thinking? I'm going to head down to the scrapyard this weekend and find a nice 1/2 ton rearend and whatever frontend conversion parts that I need. Anyone know what I need for the front? I don't want to buy half of a truck and not need it.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 04-23-2008, 07:56 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 3/4 ton -> 1/2 ton conversion..
Upper ball joints bolt into the upper control arms - easily changed out.
Spindles will need to be swapped out.
Lower control arms will need to be completly swapped out since the lower ball jonits are pressed into them and are of different diameter in the mounting holes where they're pressinto the control arms between 1/2 & 3/4 ton.
The springs will interchange. Shock mounts SHOULD be the same but double check with your local napa auto parts store to see if the mounting points on the shocks are of the same diameter. It's been too long since I last investigated it to remember that detail.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-23-2008, 05:33 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
OJOE did this recently on his 1T dually, you should be able to swap everything from the control arms out to the crossmember...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
