Old 04-23-2008, 05:33 PM   #1
jorgensensc
jorgensensc's Avatar
Can I get rid of the regulator box?
When switching to the internal alternator can i get rid of the core support mounted regulator and remove those other two wires from the harness? I'm trying to clean things up a little. Thanks!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-23-2008, 06:43 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Can I get rid of the regulator box?
If you do convert to internal reg, you will need to crimp the blue and brown wires together at the regulator, and you can get rid of the white wire. Yes you can ditch the regulator.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-23-2008, 06:56 PM   #3
chevy72blu
chevy72blu's Avatar
X2
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-23-2008, 07:16 PM   #4
jorgensensc
Okay, that is what I thought. So the red power wire just terminate it. It isn't powering anything except the regulator. Thanks guys!
DShawn
Old 04-23-2008, 10:03 PM   #5
Bus Ted Knuckle
Son of a gun
DShawn
Shawn, you do not want to terminate the red wire! It will still carry current from the alt to the bat. Your blue wire will become the wire that feeds the volt gauge, and excites the internal regulator after you connect it to the brown wire at the harness where the wires used to connect to your V.R., and then connect the other end of the blue wire to terminal #1 on the alt. The white wire will no longer be needed, so tape up the end, or remove it from the harness. You will have to make a short jumper wire to go from the big "bat" terminal to terminal #2 on the back of the alternator, that wire will power the alt.
BEATERS ARE NEATER
Old 04-23-2008, 11:28 PM   #6
jorgensensc
Bus Ted,
I'm sorry I wasn't clear. I was talking about the red wire going to the external voltage regulator. If I connect the blue and brown wire and remove the white wire, the red wire is the only one left going to the V.R., so it wouldn't be powering anything. That is what I meant by removing the red wire. Thanks for looking out for me though.
SHawn
Old 04-24-2008, 03:05 AM   #7
463
463's Avatar
http://67-72chevytrucks.com/vboard/s...=119379&page=2 this should clear you up.Trueman
Trueman
463 is offline   Reply With Quote
Old 04-24-2008, 04:27 AM   #8
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
The post for the internal alt is the quick and easy way. Heres what i did on mine with an internal and a HEI. Basically redrew the diargram, and then altered the harness to it while i had it out. Didn't take more then an afternoon. It worked out great. This way i don't have alot of loose wire in the loom cluttering up things and any hanging around able to hit the fender well or heat up.
I just had to end 1 hot red and the main junktion, remove the white to the alt, and end a ground.
Its a little unfinished, but might work.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 04-24-2008, 06:33 AM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
This works too...you just plug it in and then go work on something else that really needs your hard work.
PICKMUP is offline   Reply With Quote
Old 04-24-2008, 03:14 PM   #10
jayharrell
jayharrell's Avatar
Yeah, or that works too.. LOL
00 S10 2.2 Vin5
Old 04-24-2008, 03:30 PM   #11
Bus Ted Knuckle
Son of a gun
Gosh...I dunno, it took me all of 10 minutes to the minor wire swaps and make the change over to internal reg, including time to swap the alt. and it did not cost a dime...other than the alternator that is.
BEATERS ARE NEATER
