04-23-2008, 05:46 PM | #1 |
350 timing how much
I have a 350 in my 72 3/4 ton all stock except ceramic headers, edelbrock eps intake with edelbrock 1406 carb, MSD ignition and roller tip rockers.
I have had a problem with pinging pulling a 5000lb trailer in 95 degree heat. It also doesn't have the power to pull it up a 7% grade without some downshifting. I had the initial set at 12 and got 36 cent at 3000 and 56 with vacuum at 3000. I backed off the initial to 8 and am now at 32 cent and 50 but still have more that can come in above 3000. It is from 4 to 6 more at 3500. I am trying to tune the truck for the best gas mileage I can get but still have power to pull the trailer. I didn't have any pinging under normal conditions at 12. I have a blue and silver spring in the dizzy (lightest and one step up). I think the ideal setup should be 12 initial, 36 with mechanical and 50 TT. Does anyone have any recommendation on the timing setup? I am on port vacuum but am considering going to manifold. |
04-23-2008, 07:35 PM | #2 |
Re: 350 timing how much
What octane gas are you running?
Mike MSgt USAF (Ret) '72 Custom/20 '77 H-D Ironhead Sportster (wife's) '82 H-D FXB Sturgis '05 Trailblazer LT (wife's) |
04-23-2008, 07:50 PM | #3 |
83 With the price of gas I am not going any higher. I did get the ping to stop when I ran 92 pulling the trailer. Got better gas mileage too when not pulling the trailer. I need to tune for 83
04-23-2008, 07:58 PM | #4 |
I suspect the problem is more with vacuum advance than with mechanical - is your vacuum advance adjustable, and if so have you tried backing it off a bit? Do you have a vacuum gauge that you could provide vacuum readings under those heavy load conditions?
Changing from ported to manifold vacuum only affects idle quality, nothing else. |
04-23-2008, 10:30 PM | #5 |
The vacuum reading was zero under heavy load. The vacuum advance is not adjustable.
The truck idle fine. |
04-23-2008, 10:35 PM | #6 |
50 degrees total timing sounds like a lot to me.I believe total timing shoud be around 36 degrees +or- 2 degrees
04-23-2008, 10:51 PM | #7 | |
ZERO vacuum? This seems a bit wacky unless you're basically at full throttle - where is the gauge attached and what vacuum do you see at idle. Do you have access to a Mytivac or other calibrated vacuum source, or do you know the vacuum advance details or P/N? Sorry to ask so many questions - I'm confident the vacuum advance is the challenge here. |
04-23-2008, 10:52 PM | #8 |
Son of a gun
Mertz, you might have to break down and buy the more expensive stuff, of the cost of a tank full you are looking at about a $5 difference. I believe you will make that up in fuel economy, and not detonating your pistons.
Bill BEATERS ARE NEATER |
04-23-2008, 10:56 PM | #9 |
Around 50 is normal. 36 max for mechanical (= initial + centrifugal). Most GM GEN I vacuum advance cans provide another 15 degrees of advance at around 15 Hg. 36 + 15 = 51.
04-23-2008, 11:06 PM | #10 |
83 octane? Never seen below 87 here in SC.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-23-2008, 11:43 PM | #11 | |
Chasin' the Dream
It seems way easier to leave well enough alone, burn the cheap stuff in town and use mid or even high grade to get the performance your need when pulling a big load. Is your 'stock 350' a 1972? What is its stock HP, any idea? The powers in the octane. Just my .02.
Born with a Bowtie 1971 C/10 350/350 Daily Driver/project Assumption=The mother of all -ups |
04-23-2008, 11:55 PM | #12 | |
Seriously from your original statement I'm not sure if you mean that it knocks during a full throttle pull,or during part throttle driving. We need to know this. -Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
04-24-2008, 01:05 AM | #13 |
I ment 87 or what ever the lowest is here in WA. I had a slight ping at accelloration but very noticable pulling up the hill. I think that 36 and 51 are good. I checked the MSD info and I have the red bushing with the blue and light silver springs so I should be all in at a little over 3000 but I am getting about 4 more at 3500. I am going to double check all my numbers tonight to confirm.
04-24-2008, 01:42 AM | #14 |
04-24-2008, 03:14 AM | #15 |
Since I don't know quite as much about it as you guys, I have to keep it simple. Mine pings with 87, but runs great with 89. I could never get rid of the ping totally when I was running the 87, so I just run the 89.
04-24-2008, 05:02 AM | #16 | |
laying low
http://www.hotrodders.com/forum/dist...1-a-59033.html Anyway here is some good reading on distributors, centrifugal and vacumn advance, ported and manifold sources. How each affect performance and emissions, engine cooling and more. It's worth the read.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-24-2008, 05:13 AM | #17 | |
The GM Engineer is Lars Grimsrud, very well-known and respected in Corvette circles. |
04-24-2008, 05:21 AM | #18 | |
Gone to greener pastures
I used to run 91 octane all the time. But now, with prices being what they are, when I'm just running errands around town, I can squeak by on 89 octane. If I'm going to take a road trip, or hauling a load; I'll go up to 91 octane, and sometimes 91, with an octane booster. Just fill your tank according to your projected needs.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-24-2008, 05:48 AM | #19 |
laying low
It's right there in the article.
"Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it." The vacumn advance does more than just affect idle quality. The vacumn advance helps the driveability and fuel economy. Moving it from ported to manifold does make a difference in idle quality and driveability. Modified or stock. Mertz has driveability problems not idle probs. It's a really good article. Give it a look over.
04-24-2008, 06:21 AM | #20 | |
Look a little further down where the comment is made: "Are you using “ported” or “manifold” vacuum to the distributor? “Ported” vacuum allows little or no vacuum to the distributor at idle. “Manifold” vacuum allows actual manifold vacuum to the distributor at all times." and "An appropriately selected vacuum advance unit, plugged into manifold vacuum, can provide the needed extra timing at idle to allow a fair idle" I suspect what's happening with Mertz is in high load he's getting too much advance. He's noted that he's getting 40 mechanical (too much) and I suspect the vacuum advance is adding too much as well. Once we know more about the vacuum advance can "curve" and the vacuum he's seeing it'll be easy to debug and fix. I don't want to get into a back-and-forth (really! ) - but I just suggest you read the entire thread - carefully - and then go experiment with your car/truck. I spent a week toying with these ideas on a few vehicles. Last edited by Billla; 04-24-2008 at 06:25 AM. |
04-24-2008, 07:39 AM | #21 |
mini truck racer
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
04-24-2008, 04:04 PM | #22 |
Do you have something of value to add to the discussion? Another one for the <ignore> list...
I completely respect Boog, we just have two different perspectives on an article and we're talking through our understanding. Last edited by Billla; 04-24-2008 at 04:04 PM. |
04-24-2008, 05:42 PM | #23 |
Here are the results of this evenings test.
First, one should never rely on memory at my advanced age. I checked the springs I thought were blue and silver and they were both blue so I changed one to silver. Now I am on the E chart with a red bushing. Idle was at 650 so I bumped it to 800. Manifold vacuum was at 18. I reset the initial to 10. No adjustments to the carb. 1000 rpms no vacuum from the port no advance mechanical or vacuum manifold vacuum at 18 1500 rpms port vacuum at 4 manifold vacuum at 19 timing 21 without vacuum timing 21 with vacuum 2000 rpms port vacuum 13 manifold vacuum 19 timing without vacuum 30 timing with vacuum 40 2500 rpms port vacuum 20 manifold vacuum 20 timing without vacuum 35 timing with vacuum 54 3000 rpms ported vacuum 23.5 manifold vacuum 20 timing without vacuum 40 timing with vacuum 60 I was all in at 3000 with the new springs. The 60TT seems pretty high. Manifold vacuum was up a little. WOT nets me about 2hg. Sounds like I might need an adjustable vacuum advance or change the bushing to silver. Seems like the truck ran worse when I took it for a drive. I'll check the spark plugs again tomorrow. |
04-24-2008, 06:22 PM | #24 |
Man, this is some AWESOME detective work!! I have to say - very few people are willing to put in the work to experiment and find the problem; major props to you
I take it you're up around 2500-3000 RPM when you're towing correct? Definitely need to step up to a larger limit bushing to limit mechanical to no more than 36 degrees - as little as 32 is OK, but 36 is ideal. The additional vacuum advance is also an issue - it should be no more than 15 degrees. I see a couple of options - Lars has a list of Echlin (NAPA) advance units you could replace the existing unit with, or you can buy an aftermarket adjustable. The adjustable ones ain't cheap, but they do come with a limit mechanism so you could ensure you're getting the right max timing. I've been using the Crane unit on a number of builds and have been very happy with it. The fact that the ported vacuum doesn't match manifold vacuum until 2500 RPM is interesting - I found on my truck and a few other vehicles that they were equal at about 1500 RPM. Also interesting that the ported vacuum was higher after 3000 RPM...I need to think about that for a bit... |
04-24-2008, 06:54 PM | #25 | |
I'm a big fan of the adjustable vac-advance.Get one of those ($20+) and limit you tt (initial+mechanical) to 36 or slightly less if necessary. BTW. A 1972 350 pulling a 5000 lb trailer (plus contents?) up 7% grades in 95 deg.ambient temperature will be down shifting especially at higher elevations. I think those motors were rated at about 175 Net HP. The last time I checked,a modern 4.3 V-6 produces 195 HP. So the fact that it downshifts under those conditions is not indicative of a problem by it's self. But of course you will get more power with the spark timing set correctly. OOps,useless post,I see Billa already posted.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 04-24-2008 at 06:56 PM. |
