.....I am working on it.....
Fuel sender ohm question
I did search and confirmed that my '72 Blazer does need the 90 ohm sender. I had recently bought a 26 gal fuel cell (used) that has the 240 ohm sender. I know the gauge will not work with this as it would probably read half tank when its empty, right?? What are my options? Is there any way to "fix" the resistance of the sender? Or would it be better to just buy a new sender? I have never replaced a sender, is it just a matter of cutting the rod to length, and thats it? Thanks for any input.
![]() Join Date: Jan 2008
Re: Fuel sender ohm question
just buy a new sender they are under 100bucks im sure. it will save you alot of hassle. just my 2cents
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
Lemme show you something!!
I would contact the manufacturer of the cell and see if they have a 0-90 ohm sender. From the research I've done all the major suppliers (Jaz, RCI, Fuel-Safe, etc...) carry them. If you're running a carb and don't require an in-tank pump...the sender should be about 40 bucks.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
OK, I have been doing some research in the past hour. I think I am going to replace the sender with this one.
It costs a little more then the "universal" ones (less then $75), but it looks like it might be a liitle more durable then the arm/float style. Thanks for the replies. |
Back in the sticks
That looks cool. Is it a 90 ohm? Looks like the tank level indicators we use on ships.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
90 ohm, yes. They can make any ohm needed. These are probably used for all sorts of senders in many different applications. It looks like a well built unit, I will find out soon
A question came up...........
Does our gauges require 0 ohm full and 90 ohm empty, or is it the opposite? I can get the sender either way, just need to know the correct way for the '72 gauge. Thanks!! |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
0 ohm is empty and 90 is full. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Thank you!!
