Old 04-24-2008, 04:48 AM   #1
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
points timing
I've done a quick search and can't find my answers, so...
I'm setting the dwell and timing on my 67 with points (backfiring through intake) and I have no idea what the initial timing should be on a points type ignition, I've always run HEI. (dwell at .019)
Thanks in advance...
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 04-24-2008, 04:54 AM   #2
lowrollin70gmc
Too many projects
Re: points timing
Also, intake backfire is timing and possibly too rich, no?
Andrew
Old 04-24-2008, 05:02 AM   #3
El Jay
Gone to greener pastures
Re: points timing
the points gap should be at .019. Depending on the engine, figure 29*-34* for the dwell. 8* BTDC should get you in the ball park for the timing.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-24-2008, 08:12 AM   #4
lowrollin70gmc
Too many projects
Re: points timing
Did the points (.019) and timed it (8*) and now the dang thing won't start! I'll try again in the morning before class and if that doesn't work, I'll have to steal the HEI off my pickup.
Andrew
Old 04-24-2008, 04:26 PM   #5
Billla
Billla's Avatar
Re: points timing
If it's backfiring, either the timing is way the heck off (verify TDC, plugged vacuum advance, etc.) or you've got plug wires out of order...
Billla is offline   Reply With Quote
Old 04-24-2008, 11:02 PM   #6
lowrollin70gmc
Too many projects
Re: points timing
Tried to tie her up this morning, went to NAPA and got points, rotor, and cap (spent as much as my HEI sitting at home). That didn't work, so I looked further. Rerouted and confirmed wires, confirmed TDC with valve cover off, etc.
Then I removed the even bank valve cover as I had heard ticking noises from there this morning. And what do I see, a bent/broken pushrod on the number 4 exhaust valve. Put in new pushrod and the rocker wouldn't lash correctly (cock off to the side if twisted by hand). So I (with advice from my buddy Jeremy, an actual GM mechanic) took out the pushrods and rockers for intake and exhaust on number 4. So my 283 is now a 247! Later talked to my dad and they had a 283 when he was a teenager go on 7 cylinders for six years and multiple siblings.
Should work out for the next 2-3 weeks until the new motor and tranny get put in. I spent $70 on a free fix (timing light, feeler gauges, cap, rotor, points, etc). Oh well, good learning experience and I have a few new tools to show for it.
Andrew
