Old 04-24-2008, 06:57 PM   #1
70C10Step
70C10Step's Avatar
Driveshaft Length 700R4????
Okay guys which driveshaft can I use in 1970 stepside (Shortbed) with 350/700R4 combo? Length? Whatever info you can give me...
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 04-24-2008, 07:30 PM   #2
cdowns
cdowns's Avatar
Re: Driveshaft Length 700R4????
best advise and quicklest way to end up with only one driveshaft is to measure with a ruler or tape measure
Old 04-24-2008, 08:03 PM   #3
bills68panel
I just did this last week. you need to make sure that you have a 700r yoke that slides in the back of the trans and yes they are not all the same. slide it in all the way then pull it out 3/4 then measure from the center of where the u joint sets in the yoke to the center of where the u joint sets in at the rear end. then you got it. my drive shaft guy gave me this info.
bills68panel is offline   Reply With Quote
Old 04-24-2008, 08:10 PM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
cheapest way is to measure your truck, pretty much any measurement from the end of the transmission tailshaft, burried slipyolk center, or properly placed slip yolk center. to the rearend center of u-joint. take in ANY parts that you think can be reused, tube end yolks, tranny yolk.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-24-2008, 08:44 PM   #5
70C10Step
70C10Step's Avatar
Thanks for the help! I am getting out my ruler....
All Toys:
Old 04-24-2008, 09:10 PM   #6
whatnow123
whatnow123's Avatar
I was going to recomend the same thing as I think there are 2 different locations the trans can end up if using the 6cyl mounts or the V8 mounts.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 04-24-2008, 09:18 PM   #7
70C10Step
70C10Step's Avatar
I am using V8 mounts....
All Toys:
Old 04-24-2008, 11:00 PM   #8
bigvinnie
bigvinnie's Avatar
On my setup, I'm using a 700r4 with a longer than stock tailshaft, I believe it's the longest of the three that can be used on this trans... my stock driveshaft ended up needing no modifications as a result.
My short stepside has a smallblock in the V8 position, and the driveshaft is a one piece unit from the 6 cyl/three on the tree that the truck originally came with..
Let me know if you need more info...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 04-24-2008, 11:34 PM   #9
70C10Step
70C10Step's Avatar
Thanks for that info. I will keep you guys posted!
All Toys:
Old 04-25-2008, 08:08 PM   #10
clean71
clean71's Avatar
You can use the TH350 yoke. Measure, measure, and measure again. Don't ask me how I know.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
