Old 04-24-2008, 10:42 PM   #1
rscam
Rear mounted Tank with filler in stock location?
I want to put a tank in the rear but my truck is already painted. If I move it I'm stuck with a hole to put an antenna or something in. Has anyone heard of or done a tank move and left the filler in the stock location? It would take alot of plumbing to do but I wouldn't have to come up with something on the rear of my truck. I would just have to run some pipe. I noticed a thread where someone used copper pipe for plumbing. I can do that to!
rscam is offline   Reply With Quote
Old 04-24-2008, 10:48 PM   #2
Sammy
Re: Rear mounted Tank with filler in stock location?
Could be done but U would have 5 gals of fuel in the feeder pipe not sure I would want that. How about just leave the filler on the cab with a short piece of tank neck till you get it repainted?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-24-2008, 11:19 PM   #3
71Hulk
make the filler behind a fold down tail light and leave the original cap there as a dummy! Check out the Killer71 build up as that is what he done!
http://67-72chevytrucks.com/vboard/s...d.php?t=244448
71Hulk is offline   Reply With Quote
Old 04-25-2008, 01:35 AM   #4
Mondo
Mondo's Avatar
Be careful... I had a mechanic almost fill my cab with fuel Kind of my fault as I left it low.
My brother in-law borrowed it last week and called from the gas station.... all I pictured was him seeing gas coming out the cab corner and then calling me.
My suggestion would be to put a locking gas cap on there and don't put the key in the truck.
Mondo is offline   Reply With Quote
Old 04-25-2008, 02:03 AM   #5
jorgensensc
jorgensensc's Avatar
When I did the sidemarker fill i left the old neck and cap in place. I made a little sign that I put inside the neck that said: "NOT HERE STUPID!"
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-25-2008, 02:22 AM   #6
killer71
killer71's Avatar
Fellas just take the stock tank out and follow shifty's "how to" on the gas cap dummy! The cap is virtually screwed shut.....no way to open from outside!!!!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
