04-24-2008, 11:30 PM | #1 |
What year are these?
Purchased these on ebay last night. Said they came out of a 76 blazer? I thought 73-76 were hi-back buckets? They look like original covers whatever they are. If anyone can help with date, it would be appreciated. Thanx in advance.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
04-24-2008, 11:53 PM | #2 |
Re: What year are these?
I could believe '76. The first few years of the new body style did have low backs. I am not sure what year they went to high backs. If that is a yellow bow tie on the console it is definitely '73 or newer.
Tim |
04-25-2008, 12:10 AM | #3 |
Yes sir, it is yellow. Would the earlier style seat covers fit? They look like 71-72 seats.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 04-25-2008 at 12:12 AM. |
04-25-2008, 02:05 AM | #4 |
I think the center console is pre 73. Didn't they change to cupholders in 73 and not seatbelt holders? i think the seats are post 73. I could be wrong though.
SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-25-2008, 02:34 AM | #5 |
member #16
I had a 1975 Blazer with low back seats like yours. it also had the seat belt holder ash tray console like yours.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-25-2008, 02:54 AM | #6 |
seats are 76. 77 was first year of high backs. consle is 69-72 seat beltholders and ash tray .Old Money.
04-25-2008, 02:57 AM | #7 |
I've never tried the 71-72 covers but have heard that they will work. Those are 73-76 blazer seats. The main difference is that the brackets are a couple inches taller, and lean back a little more than the 71-72 buckets.good score!
04-25-2008, 03:58 AM | #8 |
My 76 Jimmy had those seat and console with the seat belt holders just like that.....even the same color.
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
04-25-2008, 05:12 AM | #9 |
The upolstery says`76.And,they are Blazer.The truck buckets have shorter legs.
04-25-2008, 05:16 AM | #10 |
The seat belt console did not stop with the change of body style (73).
04-26-2008, 12:26 AM | #11 |
Do ya think the seat covers for a 71-72 will fit? I can check around to find different sliders.
04-26-2008, 01:51 AM | #12 |
They should, someone had a pic of of later blazer seats covered in 71-72 covers; I think they said that the foam needed to be shaved down a little to fit. I'll try lookinn for it, not sure what it was under.
04-26-2008, 01:53 AM | #13 |
Dan, the earlier seat covers will fit --not perfect but probably good enough. The 73 low back bucket seats had a little less padding in the seat so you will have a little more material to hog ring. The console with the seat belt holder was carried over into 73++ by 77 it was the cup holder style.
04-26-2008, 02:19 AM | #14 |
Those are definitely 73-76 seats AND console. They are alot cheaper usually that the 69-72. Thr right upholstery guy can make the older seat covers work fine. On the brackets for the 69-72 truck you can get the passenger side aftermarket, and can hopefully find a set for the drivers side.
Mine are 75 true truck buckets i think( they looked just like yours) with 72 covers. I got lucky and found some factory brackets for fine.
72 Cheyenne Super 80 Silverado Blazer 2wd |
04-26-2008, 06:11 AM | #15 |
Born Psycho
my 77 blazer has low backs and my 79 had high backs.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-26-2008, 06:26 AM | #16 |
its all about the +6 inches
mannnnnnn...
Those would look totally bad ass in my burb! |
04-26-2008, 04:31 PM | #17 |
Dan, I know u just bought them but if interested in selling the seats or just the brackets keep me in mind.
Thanks. Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
