Old 04-25-2008, 08:12 AM   #1
neil alan wicks
68 k20 4 speed swap to automatic
Hey buddy's will my stock 4 speed 1968 k20 trans fer case bolt up to a automatic transmision with mounts and drive line mod's.?? or what is the best way to to swap 4 speed for an automatic transmision????
neil alan wicks is offline   Reply With Quote
Old 04-27-2008, 08:09 AM   #2
sweet70beast
sweet70beast's Avatar
Re: 68 k20 4 speed swap to automatic
The simple answer is no. The t-case adapter is different between the two and the 4 speeds output shaft has (I think) 10 splines and the auto has (i think) 30 splines. It will take some scrounging but the thing to do is find a trans, adapter and t-case and even driveshafts from an auto truck. If you get one with a 205 t-case your stock driveshafts might work if the overall length of the auto/t-case and manuel/t-case is the same. If you get one with a 203 t-case I think the driveshafts have to be shorter because the t-case is longer. If you get one with a 208 It has a slip yoke so your driveshafts won't work.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 04-27-2008, 01:31 PM   #3
I don`t believe the Rockwell case was ever mated to an automatic.I could be wrong.If they were it would be a rare find.Just find a complete auto/trans conversion.I`d buy a donor vehicle to get the whole deal.
Old 04-27-2008, 06:05 PM   #4
sweet70beast
I forgot that these had rockwell t-cases, so yeah the only way to do it is an entire swap. 4wd didn't get automatics until 71 before that all GM 4x4s were manuels.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 04-28-2008, 03:14 PM   #5
`70 had TH350/NP205s.
Old 05-05-2008, 07:37 AM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Yep my K20 Suburban came with a 350/TH350/NP205 when it was new.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 05-05-2008, 05:37 PM   #7
1969 GMC
1969 GMC's Avatar
I understand his point, though. There was never a Rockwell tcase behind an automatic. FWIW, I thought you could get an auto in a '69, because of the K5.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-05-2008, 05:45 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
some of the early K/5s had dana t-cases so auto trans might have been an option.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
