Rear end noise
Hey Guys,
I've got a whining noise coming (I think) from my rear end. Mainly when making a big sweeping right turn like gettin off the highway. It has oil in it. Any ideas? If I need to replace something in it would it be easier to buy the entire thing? What would work in my 63? Lot of questions I know, but I know no better place to ask them. Thanks, Tim |
UCA63
Re: Rear end noise
Doesn't that Fatblocker do that to you?
. . . . Sorry Tim,couldn't pass that one up LMAO
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#3 | |
Council of the Elders
Re: Rear end noise
I'm assuming 12 bolt and 1/2 ton truck. Others may have more specific diagnostic ideas.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
Re: Rear end noise
Jack it up on jack stands and run the truck in gear at idle. Then you can roll around underneath the truck and listen at each bearing location with a stethoscope to see what condition each bearing is in. If you don't have a mechanics stethescope, just use a screw driver held up to your ear. The vibrations travel thru the screwdriver and you can hear a bad bearing this way and know for sure what is bad before you tear anything apart. A bad bearing will be noticeably louder and rougher than the others. Oh and make sure your using good jack stands and not the cheap ones.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 04-26-2008 at 01:49 PM. |
Justified!
Re: Rear end noise
I would hope it's the pinion bearing, and not the gears themselves.....Thats a little cheaper to fix.....still a pain in the butt though....
Does it happen just turning right? Take the left axle out and check/replace the bearing...... Also a pain, but cheaper than a rear end.. And what HotRodYJ said.....use good jack stands....... That should be fairly easy to figure out... good luck.
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny ![]() Last edited by 64GMCHorsepower; 04-26-2008 at 03:33 PM. |
Re: Rear end noise
Besides the bearings I had a broken washer behind one of the spider gears. You'd have to pull the c-clips and axles to check these.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
