Old 04-25-2008, 11:19 PM   #1
muddpile
muddpile's Avatar
Cab fuel hole and door handle patches?
When I built my 72, pre-cut and bent patch panels were available to easily shave these areas. There was no thinking, just weld and grind. I haven't seen them for my 64, but maybe I haven't been looking in the right places. I don't have an in-cab tank anymore, and I won't have door handles much longer if I can find the patch panels to easily eliminate these things. Any help at all would be great, Thanks!
muddpile is offline   Reply With Quote
Old 04-25-2008, 11:36 PM   #2
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: Cab fuel hole and door handle patches?
I could use a fuel hole patch for a 66 myself!
Joey~AP is offline   Reply With Quote
Old 04-25-2008, 11:48 PM   #3
LILRED66
LILRED66's Avatar
The aftermarket does not offer a patch panel for shaving door handles or fuel filler neck for the '60-'66 Chevy Trucks.
LILRED66 is offline   Reply With Quote
Old 04-26-2008, 12:39 AM   #4
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Gonna have to build some yourself. I have done ALOT of these and you have to take your time on the doors. They like to move around alot. Cut your fillers a bit bigger to alow for shrinking of the door skin. Too bad you aren't in boise, I do these all day and would make you a smokin deal!
Imperial Kustom is offline   Reply With Quote
Old 04-26-2008, 06:35 AM   #5
muddpile
muddpile's Avatar
I was afraid of this.... Oh well, looks like I'll just have to take my time and carefully do it up. Thanks for the help!
Old 04-26-2008, 03:51 PM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Not everybody has acess to these, but I am making a fuel patch out of the piece off the right side of a junk cab I have, I am going to try the same with the door handle.....
there might be enough room on one door (junk with a rusty bottom ) for patches for both doors, and the fuel filler....
Old 04-26-2008, 04:09 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Have any of you tried fitting the 67-72 parts to see if using them is feasible?
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-26-2008, 07:24 PM   #8
David Flores
David Flores's Avatar
I did the same thing.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 04-26-2008, 08:04 PM   #9
muddpile
muddpile's Avatar
I've heard of the junk cab situation actually. Come to think of it, I even have a junk cab sitting out at my farm, attached to an equally junk truck. Hmmmm.... This just might work.
I haven't tried the 67-72 ones, but the door handles are 100% different and the cab profile is quite different as well.
Old 04-28-2008, 02:05 AM   #10
SeanPaintsFlames
SeanPaintsFlames's Avatar
I would think that you could just use any piece of flat metal and bend it to the curve of the door. As for the fuel hole- hammer and dolly?
Someone needs to make something like this so we behind-the-seat gas tank guys can be cool too. If I had a CNC machine I'd go for it and make millions! Nay, BIllions!
All the bikers have 'em!
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 04-28-2008, 02:55 AM   #11
62 short step
62 short step's Avatar
Man, that would be sweet!!
62 short step is offline   Reply With Quote
Old 04-28-2008, 04:14 AM   #12
Fred T
Cantankerous Geezer
Fred T's Avatar
What would be even better would be to machine the contour into the surface.
Fred
Old 04-28-2008, 05:26 AM   #13
Chevy Fleetside
Chevy Fleetside's Avatar
If you have an old door that will work also. Just cut out the countoured part put it behind the gas fill hole and trace it with a marker. it worked for me. I am sure you can do that with the handle holes also..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-29-2008, 07:03 PM   #14
muddpile
muddpile's Avatar
I think I'm going to try out the junk door thing today. Thanks guys! I have a moon tank in the bed now, so I don't need the hole in the cab real bad anymore.
Also, here's some progress pictures:
Anyways, here's the new shifter and trans tunnel. The shifter is a Lokar 32" model. It may look like it bolted in, but believe me...... There was a LOT more engineering than that, including a lever as the TH425 has a reverse shift pattern from a TH400 and this shifter was designed to be trans mounted.
The trans tunnel is no longer a tunnel at all, as there is no longer a trans. Meet "Anti-Tunnel". It will continue this way up the firewall as well.
Remember that ugly plywood bedfloor and little gas tank? Gone as well, and well replaced in my opinion.
Old 04-29-2008, 07:10 PM   #15
David Flores
nice work. looks sweet!
what steering column is that?
66 c10 swbfs
My Build.
Old 04-29-2008, 10:37 PM   #16
muddpile
muddpile's Avatar
The column is Ford Aerostar..... It works, but isn't that attractive and really doesn't fit that well. If all goes well tonight, a new Flaming River column will be in it's place.
Old 05-04-2008, 02:12 AM   #17
neto
neto's Avatar
Well I made a patch hole then hammered on it till it looked curved enough to match. After welding it, I checked for pin holes and found none. I think a little filler and it should look pretty good. Will there be any trouble with the metal not being ground flush?
neto is offline   Reply With Quote
Old 05-04-2008, 02:28 AM   #18
neto
neto's Avatar
The pictures were too big so I made them smaller to upload them. Here they are.
Old 05-04-2008, 12:53 PM   #19
jonzcustomshop
1961 crewcab
find a strait edge that you can bend-I have a thin metal ruler- bend it over the curve, the metal probably shrunk around the weld, and you should see a tiny gap under the straight edge.
If it is a high spot grind the weld some more , or tap it down with a hammer.
you could also spray a thin guide coat over it and block it to see where the high and low spots are. then tap those up / down to get it as straight as possible before applying filler.
Old 05-04-2008, 07:37 PM   #20
neto
neto's Avatar
Thanks Jon, I hadn't thought about the ruler or a straight edge. I will try to get it as close as I can.
