What was I thinking?
air valve and air line question
I ordered 8 1/2 inch valves for my truck front/back/side/side and i was gong to just use the d.o.t. line but then i changed my mind i am goin to hard line it with stainless line i can go 1/2 inch line just didnt know how difficult it would be to bend it so my question is would it be a waist of 1/2 inch valves with 3/8
line and wanting opinions on nitrogen vrs. compressors like two viarr 480 with a 5 gallon tank or something like that i would really like yalls opinion on this first truck to bag |
Re: air valve and air line question
I would go with 3/8 valves. When I did my truck, I used 1/2 valves and 1/2 line and it was WAY too fast. It was all up or all down because it was too quick to stop anywhere in between.
I ended up having to run dump adjusters on all 4 dump valves and 2 fill adjusters on my supply lines. It was $120 extra just to make it usable.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
you can use the 3/8 lines with the 1/2 valves and it wont be that bad.. but i would recomend geting the valve dump adjusters, even with 3/8 valves they would dump too fast without them. they are about 10 bucks each and you can fine tune them
viair dual pack would be a good comp set. i have the 400's which is good for here in arizona in the summer heat.. they have a thermo shut off switch that you wont find in some of the others, they are 150 psi rated and push good cfm
I didn't think about running adjusters on the 3/8. Another advantage is the adjusters also quiet the valves. The 1/2 valve was LOUD when it dumped.
thanks i am goin to run 3/8 line with my 1/2 inch valves. i dont know anything about dump adjusters never heard of them what exactly are thay and were can i get them? and as far as compressors or nitrogen not for sure. how many amps would a dual comp pull? my altanator is brand new but it is only 65 amps . thanks
![]() Join Date: Apr 2004
What about a york engine driven compressor? They put out tons of air. I've had mine running for about a week and I love it.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
On my suburban I have Accu Air Control Systems with 12 valves. 8 - 1/2" valves and 4 -1/8" valves. The Accu Air sets my system with the 1/8 valves. I also have them hooked to a toggle switch to activate the smaller valves. I also changed my 1/2" lines to 1/4" out from the valve, 1/2" on the supply side. The 1/2" lines were fun for a little while, but I want to get in my ride and drive it, not adjust my system.
compressors pull 30-50 amps. depending on what setup you have, but you should always let your truck run while the comps. are running.
here is a pic of the speed controller/silencer. Last edited by bedsled71; 04-30-2008 at 04:29 PM. |
#10 | |
[IMG]http://*****************/images/products/mid_12NPTValveDumpControl.jpg[/IMG]
thanks everyone but i went and got about 60 foot of 1/2 stainless line and most of my fittings. i still need to get more. i just think it would be more fun and im not going to drive this truck all the time i have a 72 as my daily driver
