Old 04-26-2008, 05:20 AM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Easy Aluminum Radiator Upgrade....See Pics!!
I finally had some extra time to install the Summit Radiator I purchased days ago.
I decided to make this an easy bolt on install for those of you who might not have a welder.
Follow along as I explain in detail how I did this to my truck this afternoon:
First of all, my truck ran at a cool 180* constantly....with the original tiny sixer radiator. So running hot was never a problem, I only did this swap just for the 'cool' factor...
Here's the stocker...Didn't look too bad though:
Drained the sucker:
This is the part number I went with:
I decided I didn't want it the stock location, but rather flush with the radiator support:
I used the existing holes shown in the red circles.....behind those you can see the stock mounts:
After a couple of measurements, I found I only needed a 1" lift on the radiator.
The material used was a 16" piece of 1x2 rectangular tubing, centered the tubing between the frame-rails and marked to holes. I used 3/8" x 1" allen head bolts. I was gonna just tack weld bolts under the tubing, but again I wanted to show a "drill and bolt" install.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-26-2008, 05:39 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Easy Aluminum Radiator Upgrade....See Pics!!
I center the tubing in the frame rails...however the existing holes are 1/2" offset. Dimensions are shown at the end.
For the upper mounts, I used 5/16" stud vibration mounts. Here I drill the existing holes to 1/4", then tapped to 5/16" coarse thread. You can just drill to 5/16" then nut from behind if you wish.
Dropped the radiator in place, centered it up (between the frame-rails), then marked and drilled the flange.
The reason I used the 1x2, is because if fits snug in the radiator bottom, with about 3/16" clearance just enough for some rubber cushion.
Here's some measurements:
16" long...one side is 2" in, and other side is 1 1/2" in, and 1 9/16" from the edge for your centers:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-26-2008, 05:42 AM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I also like the fact that the radiator neck is tapped for 1/8" pipe. The connection here it a temporary connection.
I need to come up with a new hose for the bottom, and rework the upper hose as well.
I think this made for a pretty easy and straight forward install.
I might throw my buffers on the bench grinder and hit up the tanks before running it...only time will tell...
Later
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-26-2008, 06:29 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Well done, John. Now we need some shot of the finished product. Is there a shroud in the making?
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-26-2008, 06:42 AM   #5
joe231
joe231's Avatar
nice write up! thanks
CHEVY ONLY
Old 04-26-2008, 07:07 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I should have it done tomorrow....Then I'll post up some more pics. I wasn't planning on a shroud...mabey just an electric fan in the near future.
No problem, man !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-26-2008, 07:53 AM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Thumbs up Re: Easy Aluminum Radiator Upgrade....See Pics!!
Nice John.......you'll like this radiator. I did this years ago.........completely different way. I used 2 polyurethane bump stops in the existing holes on the bottom and then mounted the top w/ a 67-72 mount on top w/ another bumpstop.
no shroud and 400ci never gets hot, even in 100* plus temps.........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-26-2008, 04:03 PM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool man....I thought about the bump-stops too, however I didn't have the perfect size in stock...and they wouldn't of worked as the tubing was offset to give me my 3/4" clearance....Mabey I'll change it in the future...but for now it works great !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-26-2008, 06:33 PM   #9
slepysal
slepysal's Avatar
Man , that looks nice! I showed my brother in law this post, he just spent300.00 on a stock one.!! ( like I did for mine) Nice job
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-26-2008, 07:43 PM   #10
SeanPaintsFlames
SeanPaintsFlames's Avatar
That's how my truck's PO mounted the radiator when they dropped a 350 in. That's also the reason my know-it-all mechanic friend gave for my truck overheating every time I got stuck in traffic. Apparently, my radiator is too far away from the fan to make it work properly.
Does yours still stay cool enough?
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 04-26-2008, 08:58 PM   #11
rickf
rickf's Avatar
The holes the Chief used are for the stock OEM "big" radiator (for big 6 and v8 options), the smaller radiator further back and lower was only for th 230L6. I believe the v8 only had the "short" water pump in that era, so an original OEM style fan shroud should be a proper fit and should resolve your fan-too-far-away issue.
The shroud mounts to sheet metal that in turn mounts to the radiator support, not to the radiator itself. So it ought to work with a variety of radiators.
The shrouds are available, when I was looking they were $100 to $120 depending on source.
Beautiful job Chief, of course I'd expect nothing less given the history with other projects you've shown here.
rickf is offline   Reply With Quote
Old 04-27-2008, 02:44 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks man.....So far I have $169 for the radiator...metal, bolts and vibration mounts I had already.
I haven't run it yet, but as I mentioned before, my 230 6 cyl radiator kept my 350 @ a constant 180*...idle, traffic, whatever.....So since the new radiator is made of alumium, it should disappate even better....We will see. I want to get rid of that ugly fan anyway...might go with an electric.
Thanks for the added info and the compliments......I set my truck back on the b-burner again.....Should have it ready on Monday.
Later
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-27-2008, 03:27 AM   #13
David Flores
David Flores's Avatar
Looks good. I just ordered a summit radiator with trans cooler(SUM-381428)
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 04-27-2008, 04:06 AM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-27-2008, 04:43 AM   #15
Iron-Butt
454 club
Iron-Butt's Avatar
Nice write up. I might need to change mine out since I just installed the old air kit.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 04-27-2008, 04:55 AM   #16
**grumpy**
**grumpy**'s Avatar
Great choice.
I've used those Summit universal aluminum rads. in 3 vehicles.
My 53 suburban
a 57 chevy wagon
and a 59 chevy wagon.
best 170. bucks I spent.
Plus Summit is only 35 minutes from my house, so I just run there and pick stuff up.
Road Hounds
**grumpy** is offline   Reply With Quote
Old 04-27-2008, 05:35 AM   #17
Brianflores
Brianflores's Avatar
real nice, it's good to have time to work on the truck........
Welding cant be that hard, right?
Brianflores is offline   Reply With Quote
Old 04-27-2008, 05:05 PM   #18
billydonn
Council of the Elders
billydonn's Avatar
Snazzy post Chief! Try a lower rad hose for 66 c-10 with 327. That should get you close...they use the front rad position and are mounted higher.
Your overflow is plumbed to the bottom of that catch can, I assume.
66 C-10 Stepside
350 Tuned Port Injection
Tremec TKO-600
Truck Pictures: http://community.webshots.com/user/billydonn
Truck Video: http://good-times.webshots.com/video...ost=good-times
billydonn is offline   Reply With Quote
Old 04-27-2008, 09:08 PM   #19
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool man, thats what I need to know !!
Yes, that's where it's going.....I think I might run an AN fitting off of the radiator, with an elbow. This will look much better then whats on there now.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-28-2008, 06:18 PM   #20
Slowmotion
Everytime I Ck On This Site I See That You Have Done Something New To Youre Truck. It Just Keeps On Getting Better And Better. Keep Up The Good Work. I Enjoy Seeing The Progress.
Slowmotion is offline   Reply With Quote
Old 04-28-2008, 08:15 PM   #21
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Cool, cool...thanks bro
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-28-2008, 08:54 PM   #22
salazar44
65 - Chevy C10
salazar44's Avatar
I would like to do this also, but dont know how everyone else is running the tranny cooler lines. Or where they are putting the tranny cooler. I have a powerglide.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 04-28-2008, 10:35 PM   #23
David Flores
Try SUM-381428 from summit.
66 c10 swbfs
My Build.
Old 04-29-2008, 03:44 AM   #24
Woogeroo
So, how do those metal radiator hoses work? How do they tighten up? Just curious...
thanks for sharing and all the picture taking!
-W
Woogeroo is offline   Reply With Quote
Old 04-29-2008, 03:46 AM   #25
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
That would be a good choice....Although, when I convert my truck from the stock 3-speed over to the 700R4, I am going to run a nice, over kill tranny cooler. I used a really sweet one from Summit one time on a boosted Diesel Excursion...It had 1/2 ports w/a thermostatically controlled fan...Don't think I have to go that crazy, but there are options out there.
No sense in running your fluid thru boiling water.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
