Old 11-03-2002, 12:33 AM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Question Shock relocaters??
Those of you with lowered trucks and shock relocators, do they actually work? Do you notice a ride improvement with them? I have a 4" drop and I'm always bottoming out on the bumpers. I can't afford a C-notch yet and hope that this might help alot.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-03-2002, 01:24 AM   #2
crazy longhorn
Fabricate till you "puke"
Relocating the shocks will help the ride, but Im not sure it will help with bottoming. you might try trimming the bumpstops to about 1/2 the thickness....might grab you another 1" clearance. i dont run bumpstops on the rear of the longhorn. I have a 5" drop , with 3" clearance tween the frame & axle& dont bottom. The springs are pretty firm tho......3/4 ton leaf with a couple leafs removed. i fabbed a set of shock relocators , both front & rear to run a set of Monroe Gas LTs. It did help with the ride. Good luck....crazy AL
crazy longhorn is offline   Reply With Quote
Old 11-03-2002, 03:45 AM   #3
Brad
Brad's Avatar
Yeah, I already cut the bumpstops just enough so the axle doesn't hit the frame. I've also got coils. Sent you a PM
Old 11-03-2002, 12:42 PM   #4
crazy longhorn
I havent looked at a coil frame for some time now, but memory has the bumpstops outside the frame rails? If you take the stops & brackets completely off...... will you gain any clearance?
Old 11-03-2002, 01:16 PM   #5
MikeB
MikeB's Avatar
I got mine from Early Classics back in 1998. Before I installed them, the back of my truck bounced around a lot. Every dip or rise in the road made it oscillate a couple times before it settled down, even with new KYB gas shocks. I have 3" drop springs, but even with stock springs, IMO, the rear shocks were at too much of an angle to do much good. When the axle moved 6", the shocks would move only 2", so they never had a chance to work.
The brackets stand the shocks up closer to vertical, which lets them travel more. This makes a TREMENDOUS difference in their ability to dampen oscillations. Along with a rear stabilzer bar, these brackets are among the best enhancments you can make to your truck's ride and handling.
By the way, good quality 4" lowered TRUCK springs should not cause your suspension to bottom out. Properly designed lowered springs are stiffer to compensate for less travel. Cheapo springs are simply shorter with the same resistance rate. I doubt the shock relocation brackets will help compensate for springs that are too soft.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-04-2002, 03:27 PM   #6
Brad
Brad's Avatar
Crazy longhorn-I'm at the lowest I can be without a C-notch.
MikeB-Thanks, it sounds like I just need to invest in a pair then. I'm having problems with the $60 price though. Did you have to use shorter shocks, or can I get by with regular length until they go belly up? I thought my springs were 4" but maybe they're 6". They're Eibach springs fwiw.
Old 11-05-2002, 11:52 AM   #7
MikeB
MikeB's Avatar
I can't remember whether my rear shocks are stock height. I got them from Early Classics along with the rear springs. With a 6" rear drop, you need really stiff springs or a notch to not bottom. I'm only at 3".
Mike
Old 11-06-2002, 06:02 AM   #8
Brad
Brad's Avatar
Unhappy
Well, as I was putting in my new rearend I noticed that my driver side shock is bad and the other one is going. I just bought these about 2 years ago from ECE. How long do shocks last?
Old 11-06-2002, 08:54 PM   #9
dregs454
Killin' Time
dregs454's Avatar
Question: Would buying shorter shocks solve the problem of poor shock angles with a drop?
(for example, 5 inch rear drop coils, and 5 inch shorter springs)
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Dynomax headers and 2.5" duals
dregs454 is offline   Reply With Quote
Old 11-07-2002, 12:25 AM   #10
Brad
Brad's Avatar
I don't think it would since you'll still have too much angle.
Old 11-07-2002, 03:47 AM   #11
Alexis
Member since 2000
Alexis's Avatar
Eibach doesnt make 6 inch lowering springs. i think
wanna bet
Alexis is offline   Reply With Quote
Old 11-11-2002, 12:20 AM   #12
Slammed67
Progress = 0%
Slammed67's Avatar
Brad,
By chance are your shocks bottoming out? You said they were going bad and they are only 2 years old?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-11-2002, 05:32 AM   #13
Brad
Brad's Avatar
nope-I unbolted the plate as I was installing the new rearend and I could push and pull the shock with no resistance. Yeah, the driver side one is dead alright. The passenger side is still good. I'm going to double check on the time frame though. They're the silver KYB too. I've gotta bite the bullet and get lowered shocks now.
Old 11-16-2002, 03:09 PM   #14
swervin ervin
You get what you pay for
swervin ervin's Avatar
I'm not sure on 67-72's, but the shock extenders work great on my 85. I was able to use stock length Edelbrock IAS's on a 5" drop.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-18-2002, 01:37 PM   #15
powder
the ring around my finger
powder's Avatar
SHOCKS
THIS OLD MAN SHOWED ME A TRICK YOU USE 70-79 CHEVY VAN SHOCKS THE DO THE SAME THING DROP SHOCKS DO FOR ABOUT 50.00 LESS
powder is offline   Reply With Quote
Old 11-18-2002, 07:33 PM   #16
Brad
Brad's Avatar
Thumbs up
Cool! For awhile now I've been thinking that there was a cheaper solution. I looked through a book once, but couldn't find the right ends with a shorter length. I'm going to run right out and replace my shocks now! THANKS!
I went and checked on 79 shocks and they're only about an inch shorter. I need more than this. I think I'll go with drop shocks.
